6.2.2 ROS 2 RViz2 Visualization on Windows
This guide explains how to set up and use RViz2 which is the official 3D visualization tool in ROS 2. It is used to display:
- Robot models
- Sensor data (point cloud, LiDAR, camera)
- Path planning and navigation results
Open Source Repository: ros2/rviz2
Using RViz2 requires a ROS 2 installation. While typically installed on Linux, several options exist for running it on Windows.
Method | Key Characteristics |
Virtual Machine | - Near-native Linux experience, best compatibility - Development environment matches deployment |
Native Windows Install | - Direct integration with Windows OS - Requires admin rights; complex environment variable setup |
WSL2 | - Close to native Linux performance - Requires admin rights; complex file system interaction with Windows |
Pixi | - Newer ecosystem, may require custom environment setup - No admin rights required; lightweight |
The rest of this section explains how to use Pixi to install ROS 2 on Windows 10 and run the RViz2 visualizer.
Step 1: Install Pixi
- Go to the Pixi releases page: Pixi
- Download the
pixi-x86_64-pc-windows-msvc.zip
file. - Extract the downloaded ZIP file.
- Move the extracted
pixi.exe
file to the directory:C:\Users\[YourUsername]\.pixi\bin
Step 2: Configure Environment Variables
- Right-click on This PC and select Properties.
- Click on Advanced system settings.
- In the System Properties window, click the Environment Variables... button.
- In the System variables section, find and select the Path variable, then click Edit....
- Click New and add the path:
- Click OK to close all dialogs.
Verify the Installation:
Open PowerShell.
Run the command:
pixi --version
Step 3: Install ROS 2
Press
Win + R
, typecmd
, and press Enter to open a Command Prompt window. -
Run the following commands sequentially:
pixi init pixi-ros2 -c https://prefix.dev/conda-forge -c "https://prefix.dev/robostack-humble"
cd pixi-ros2
pixi add ros-humble-desktop -
After installation, launch RViz2 with:
pixi run rviz2
