6.4.1 Automatic Speech Recognition (ASR)
This module converts spoken audio into text using the SenseVoice ONNX model — a process known as Automatic Speech Recognition (ASR)
It captures audio from a microphone, performs inference on the SpacemiT computing cores, and publishes recognition results as ROS 2 messages.
The system supports a wake word + speech recognition pipeline out of the box, enabling voice-controlled interaction.
Typical applications:
- Smart home voice control
- Service robot voice command interaction
- Industrial voice assistance systems
- Touchless voice-controlled devices
Install System Dependencies
Configure Python Virtual Environment & Install Dependencies
# Set mirror source (recommend Tsinghua mirror)
# Create and activate a virtual environment
python3 -m venv ~/asr_env
source ~/asr_env/bin/activate
# Install dependencies
pip install -r /opt/bros/humble/share/jobot_voice/requirements.txt
The jobot_voice/
directory is pre-installed in the system and ready for use.
Configure User Audio Permissions
Activate Runtime Environment
# Activate ROS 2 and Python virtual environment
export PYTHONPATH=~/asr_env/lib/python3.12/site-packages/:$PYTHONPATH
Check Available Recording Devices
arecord -l
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: XFMDPV0018 [XFM-DP-V0.0.18], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Here, card 1
is the USB microphone device.
Assign 1
for the device_index
in later launch commands.
Start Speech Recognition
Launch the ASR node with:
ros2 launch br_perception asr_wakeword.launch.py \
rate:=16000 \
device_index:=1 \
min_db:=4000
Important Notes:
- After launch, the system listens for wake words (default: "你好/Nihao")
- Automatically records and recognizes speech upon wake word detection
- Recognition results are published via ROS2 messages
- Some USB microphones only support
48000
Hz - adjust therate
parameter accordingly
Example terminal output:
[wakeword_asr_node-1] jack server is not running or cannot be started
[wakeword_asr_node-1] JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
[wakeword_asr_node-1] compiler_depend.ts(51) LOG(INFO) precompiled_charsmap is empty. use identity normalization.
[wakeword_asr_node-1] Detected optimized model, loading directly: /home/zq-pi/.cache/sensevoice/model_quant_optimized.onnx
[wakeword_asr_node-1] Listening for wake word...
[wakeword_asr_node-1] Voice activity detected, starting recording...
[wakeword_asr_node-1] Silence detected for 1.0s, stopping recording.
[wakeword_asr_node-1] Closing audio stream
[wakeword_asr_node-1] wake check: Hello
[wakeword_asr_node-1] Wake word detected!
[wakeword_asr_node-1] Listening for user speech...
[wakeword_asr_node-1] User said: How's the weather today
Subscribe to Recognition Results
The recognition results are published to the ROS 2 topic /voice_text
, using the standard std_msgs/msg/String
message type:
ros2 topic echo /voice_text
Example:
data: What's the weather like today?
Parameter Description
Parameter Name | Description | Default Value |
sld | SSilence duration (seconds) to stop recording after speech ends | 1.0 |
min_db | Minimum volume threshold to start recording (higher = louder trigger) | 2000 |
max_time | Max duration (seconds) for a single recording before returning to wake mode | 30 |
channels | Number of audio channels | 1 |
rate | Audio sampling rate (e.g. 16000 , 48000 ) | 48000 |
device_index | Audio capture device ID (query via arecord -l ) | 1 |
result_topic | ROS 2 topic for recognition results | voice_text |
