Bianbu 2.0 Release Notes
Build from Ubuntu 24.04 sources.
Bianbu 2.0 source:
Types: deb
URIs: https://archive.spacemit.com/bianbu/
Suites: noble/snapshots/<version> noble-security/snapshots/<version> noble-porting/snapshots/<version> noble-customization/snapshots/<version>
Components: main universe restricted multiverse
Signed-By: /usr/share/keyrings/bianbu-archive-keyring.gpg
<version>
should be replaced with a version number, such as v2.0.4. If you need to download the source code, please change Types: deb
to Types: deb deb-src
v2.0.4
Release date: 2024-12-11
Bianbu Linux version: v2.0.4
Major Updates
- Fixed the issue of Chromium crashing after long periods of online video playback
- Fixed screen recording color issues
- Fixed Remmina connection crashes
- Upgraded LLVM to 18.1.8-11
- Upgraded Mesa to 24.01
- Optimized startup time
- Optimized desktop animations and search services
- Added support for VSCodium (codium)
- Added support for Zed (spacemit-code-forge)
- Added support for GRUB
- Added support for Fcitx5 (default input method)
v2.0.2
Release date: 2024-11-11
Bianbu Linux version: v2.0.2
Major Updates
- systemd supports wakeup count
- mesa supports AMD R600 driver
- Fixed GDB vector debugging issues
- Fixed mutter compatibility issues with internal and external graphics cards
v2.0.1
Release date: 2024-10-28
Bianbu Linux version: v2.0.1
Major Updates
- Update BSP related components
v2.0
Release date: 2024-10-22
Major Updates
- Fix the issue of "Failed to start plymouth-quit-wait" prompt on first startup
- Fix the status bar color issue in light theme
- Upgrade LLVM 18 to 18.1.8
- Upgrade GCC 14 to 14.2
- Update img-gpu-powervr to fix the gnome-shell compilation error
v2.0rc2
Release date: 2024-9-30
Bianbu Linux version: v2.0rc7
Major Updates
- Fix the issue of Chromium crashing when playing videos
- Fix the issue of Chromium cookies becoming invalid
- Update box64 to support RVV and running WPS Office
v2.0rc1
Release date: 2024-9-7
Bianbu Linux version: v2.0rc6
Major Updates
- Support python3-gpiozero
- Support code-server
- Support apport
- gnome-initial-setup support set hostname
v2.0beta2
Release date: 2024-9-2
Bianbu Linux version: v2.0rc5
Major Updates
- Fix serial can not login when HDMI as primary screen and not connected
- Fix ssh unsupport compress issue
