5.8.2 Isaac Sim 仿真导航
⚠️运行环境说明:
Isaac ROS Occupancy Grid Localizer 简介
该案例借助 Isaac ROS Occupancy Grid Localizer 实现地图本地化(定位),使用标准 Nav2 进行导航。
Occupancy Grid Localizer 是一个基于已知栅格地图和激光传感器数据来实现 2D 定位的模块,最终输出机器人在地图中的位姿。
Isaac ROS Occupancy Grid Localizer 定位器设计:
该定位器有两个主要节点:
  • Occupancy Grid Localizer Node:NVIDIA 提供的占用栅格定位器(将激光雷达数据匹配到地图)
  • Laser Scanto FlatScan Node:将平面2D/3D 激光雷达数据转换成 Issac ROS 内部标准格式
仿真流程
image-20250529192447283
下载离线资源
登录AI服务器,下载issac-ros-vslam案例配套的资源包:
NGC_ORG="nvidia"
NGC_TEAM="isaac"
PACKAGE_NAME="isaac_ros_occupancy_grid_localizer"
NGC_RESOURCE="isaac_ros_occupancy_grid_localizer_assets"
NGC_FILENAME="quickstart.tar.gz"
MAJOR_VERSION=3
MINOR_VERSION=2
VERSION_REQ_URL="https://catalog.ngc.nvidia.com/api/resources/versions?orgName=$NGC_ORG&teamName=$NGC_TEAM&name=$NGC_RESOURCE&isPublic=true&pageNumber=0&pageSize=100&sortOrder=CREATED_DATE_DESC"
AVAILABLE_VERSIONS=$(curl -s \
-H "Accept: application/json" "$VERSION_REQ_URL")
LATEST_VERSION_ID=$(echo $AVAILABLE_VERSIONS | jq -r "
.recipeVersions[]
| .versionId as \$v
| \$v | select(test(\"^\\\\d+\\\\.\\\\d+\\\\.\\\\d+$\"))
| split(\".\") | {major: .[0]|tonumber, minor: .[1]|tonumber, patch: .[2]|tonumber}
| select(.major == $MAJOR_VERSION and .minor <= $MINOR_VERSION)
| \$v
" | sort -V | tail -n 1
if [ -z "$LATEST_VERSION_ID" ]; then
echo "No corresponding version found for Isaac ROS $MAJOR_VERSION.$MINOR_VERSION"
echo "Found versions:"
echo $AVAILABLE_VERSIONS | jq -r '.recipeVersions[].versionId'
mkdir -p ${ISAAC_ROS_WS}/isaac_ros_assets && \
FILE_REQ_URL="https://api.ngc.nvidia.com/v2/resources/$NGC_ORG/$NGC_TEAM/$NGC_RESOURCE/\
versions/$LATEST_VERSION_ID/files/$NGC_FILENAME" && \
curl -LO --request GET "${FILE_REQ_URL}" && \
tar -xf ${NGC_FILENAME} -C ${ISAAC_ROS_WS}/isaac_ros_assets && \
rm ${NGC_FILENAME}
fi
安装/编译 Isaac ROS Occupancy Grid Localizer
进入 issac-ros-dev,安装/编译 issac-ros-visual-slam 包。
  • 安装预编译包:
sudo apt-get update
sudo apt-get install -y ros-humble-isaac-ros-occupancy-grid-localizer
  • 源码编译:
cd ${ISAAC_ROS_WS}/src
git clone -b release-3.2 https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_map_localization.git isaac_ros_map_localization
sudo apt-get update
rosdep update && rosdep install --from-paths ${ISAAC_ROS_WS}/src/isaac_ros_map_localization/isaac_ros_occupancy_grid_localizer --ignore-src -y
cd ${ISAAC_ROS_WS}
colcon build --symlink-install --packages-up-to isaac_ros_occupancy_grid_localizer --base-paths ${ISAAC_ROS_WS}/src/isaac_ros_map_localization/isaac_ros_occupancy_grid_localizer
启动仿真
在 GPU 服务器上启动仿真。
启动 IsaacSim
cd issacsim
./isaac-sim.sh
加载场景和小车模型
参考:https://nvidia-isaac-ros.github.io/getting_started/isaac_sim/index.html
修改话题名称
在视图右部 Stage 栏目,选择 /World/Nova_Carter_ROS/ros_lidars/publish_front_2d_lidar_scan,将 2D 雷达发布的话题名称修改为 /scan,这是为了与 Nav2 导航栈的标准接口兼容。
启用雷达
在视图右部 Stage 栏目,选择 /World/Nova_Carter_ROS/ros_lidars/front_2d_lidar_render_product,在Inputs属性里面勾选 enabled,启用 2D 雷达输出,让 ROS2 驱动节点可以从仿真中接收到模拟的 2D 激光雷达数据。
启动仿真过程
点击视图左边的 PLAY 按钮,这一步是使场景开始运行,机器人和传感器上电,雷达开始采集数据并发布话题,控制器准备监听订阅的话题(比如速度)。
启动导航
ros2 launch isaac_ros_occupancy_grid_localizer isaac_ros_occupancy_grid_localizer_nav2.launch.py
上述脚本启动 isaac_ros_occupancy_grid_localizer 的导航脚本,启动以下节点和功能:
节点/组件功能描述
rviz_launch启动 RViz 并加载预配置的可视化界面
nav2_bringup_launch启动 Nav2 核心组件,包括控制器、全局/局部规划器等
OccupancyGridLocalizerNodeNVIDIA 提供的占用栅格定位器,将激光数据匹配到栅格地图实现定位
LaserScantoFlatScanNode将 3D/2D激光雷达数据转化成FlatScan格式供定位器使用
static_transform_publisher发布 base_linkbase_footprint 的静态 TF
导航启动之后,需要初始化起始位置,执行下列命令触发本地化服务:
ros2 service call /trigger_grid_search_localization std_srvs/srv/Empty {}
此时,机器人已经进行本地化,可以在 RVIZ 视图中点击 Nav2 Goal,选择地图上的一个点,Nav2 会规划导航路线,控制器会驱动机器人沿航线运动:
