消息接口说明
音频消息
消息文件位置:jobot_interfaces/msg/AudioFrame.msg
用于传输音频数据流,包含时间戳、采样信息和原始 PCM 数据。
消息定义
# 头部,包含时间戳和frame_id
std_msgs/Header header
# 采样率
int32 sample_rate
# 声道数
int32 channels
# 格式(0=PCM16, 1=float32)
int32 sample_format
# 每一帧音频数据(int16 PCM)
int16[] data
字段说明
| 字段名 | 类型 | 说明 |
header | std_msgs/Header | ROS 标准消息头,包含时间戳和 frame_id |
sample_rate | int32 | 采样率(Hz),如 16000、48000 |
channels | int32 | 声道数(1=单声道,2=立体声等) |
sample_format | int32 | 数据格式:0=PCM16,1=float32 |
data | int16[] | 音频帧数据(PCM 16bit 小端序) |
使用说明
订阅该消息时,可以通过 header.stamp 获取时间戳, 用于和其他传感器同步;
sample_rate 和 channels 用于解码音频数据;
data 则是原始音频样本数组,可以直接写入 WAV 文件或输入到 ASR 模型。
Python 订阅示例(rclpy)
from jobot_interfaces.msg import AudioFrame
class AudioSubscriber(Node):
super().__init__('audio_subscriber')
AudioFrame,
'audio_frames', # 话题名
self.callback,
10
def callback(self, msg: AudioFrame):
self.get_logger().info(
f"Received audio: rate={msg.sample_rate}, "
f"channels={msg.channels}, "
f"format={msg.sample_format}, "
f"len(data)={len(msg.data)}"
# 例如:取前 10 个采样点
print("Samples:", msg.data[:10])
node = AudioSubscriber()
C++ 订阅示例(rclcpp)
#include "rclcpp/rclcpp.hpp"
#include "jobot_interfaces/msg/audio_frame.hpp"
using std::placeholders::_1;
class AudioSubscriber : public rclcpp::Node
public:
AudioSubscriber() : Node("audio_subscriber")
subscription_ = this->create_subscription<jobot_interfaces::msg::AudioFrame>(
"audio_frames", 10, std::bind(&AudioSubscriber::callback, this, _1));
private:
void callback(const jobot_interfaces::msg::AudioFrame::SharedPtr msg)
RCLCPP_INFO(this->get_logger(),
"Received audio: rate=%d, channels=%d, format=%d, len(data)=%zu",
msg->sample_rate, msg->channels, msg->sample_format, msg->data.size());
// 示例:输出前 10 个采样点
for (size_t i = 0; i < std::min((size_t)10, msg->data.size()); i++)
std::cout << msg->data[i] << " ";
std::cout << std::endl;
rclcpp::Subscription<jobot_interfaces::msg::AudioFrame>::SharedPtr subscription_;
int main(int argc, char * argv[])
rclcpp::init(argc, argv);
rclcpp::spin(std::make_shared<AudioSubscriber>());
rclcpp::shutdown();
VAD
消息文件位置:jobot_interfaces/msg/VADResult.msg
该消息用于表示语音活动检测(Voice Activity Detection, VAD)的结果,包含语音出现的概率和是否检测到语音。
消息定义
float32 prob # 语音概率
bool is_speech # 是否检测到语音
字段说明
| 字段名 | 类型 | 说明 |
header | std_msgs/Header | ROS 标准消息头,包含时间戳和 frame_id,用于与音频帧进行时间同步 |
prob | float32 | 语音活动概率,范围 [0.0, 1.0],表示当前帧包含语音的置信度 |
is_speech | bool | 是否检测到语音,true=有人声,false=无人声 |
使用场景
- 语音触发:可用于唤醒词检测前的语音段检测,减少误触发。
- ASR 前处理:在传给语音识别(ASR)前过滤掉静音帧,节省计算资源。
- 机器人对话系统:在多模态交互中,判断用户是否正在说话。
Python 订阅示例
from jobot_interfaces.msg import VADResult
class VADSubscriber(Node):
super().__init__('vad_subscriber')
VADResult,
'vad_result',
self.callback,
10
def callback(self, msg: VADResult):
f"[VAD] prob={msg.prob:.2f}, is_speech={msg.is_speech}"
node = VADSubscriber()
C++ 订阅示例
#include "jobot_interfaces/msg/vad_result.hpp"
class VADSubscriber : public rclcpp::Node
public:
VADSubscriber() : Node("vad_subscriber")
subscription_ = this->create_subscription<jobot_interfaces::msg::VADResult>(
"vad_result", 10, std::bind(&VADSubscriber::callback, this, _1));
private:
void callback(const jobot_interfaces::msg::VADResult::SharedPtr msg)
"[VAD] prob=%.2f, is_speech=%s",
msg->prob, msg->is_speech ? "true" : "false");
rclcpp::Subscription<jobot_interfaces::msg::VADResult>::SharedPtr subscription_;
rclcpp::spin(std::make_shared<VADSubscriber>());
rclcpp::shutdown();
