MobileNetV2
The MobileNetV2 example demonstrates how to classify objects in images or video streams using the SpacemiT AI processor. The inference node outputs the predicted object class as a ROS 2 message.
Supported classes: MobileNetV2 can classify 1,000 object types,including people, animals, fruits, and vehicles. Refer to the official COCO labels for a complete list of supported categories.
Typical applications: MobileNetV2 can predict the category of a given image and is commonly used in object recognition, digit recognition, image retrieval, and text recognition.
Platform Requirements
SpacemiT RISC-V:
- Pre-flashed with the Bianbu ROS system image
Install dependencies
Import ROS 2 Environment
Model Configuration Check
Run the following command to list the model configurations currently supported on your system:
ros2 launch br_perception infer_info.launch.py | grep 'classification'
Sample output:
Example, to use the ResNet18 model, set
config_path:=config/classification/resnet18.yaml
Running Inference on an Image
Copy a test image to your current folder:
cp /opt/bros/humble/share/jobot_infer_py/data/classification/kitten.jpg .
Run inference and print results only
config_path:='config/classification/mobilenet_v2.yaml' \
img_path:='./kitten.jpg'
Sample terminal output:
[INFO] [infer_img_node-1]: process started with pid [527993]
[infer_img_node-1] class predict: n02124075 Egyptian cat
[INFO] [infer_img_node-1]: process has finished cleanly [pid 527993]
Viewing Inference Results in a Web Browser
Terminal 1 – Run the inference node:
img_path:='./kitten.jpg' \
Sample output:
[INFO] [launch]: All log files can be found below /home/zq-pi3/.ros/log/2025-04-28-14-23-22-474545-spacemit-k1-x-MUSE-Pi-board-528137
[INFO] [infer_img_node-1]: process started with pid [528138]
The prefix n02124075 is the ImageNet class index
Terminal 2 – Launch the WebSocket viewer:
Sample output (WebSocket viewer):
[websocket_cpp_node-1] Please visit in your browser: 10.0.91.140:8080
Note: Visit the IP shown after "Please visit in your browser:" (here 10.0.91.140:8080) to view inference results. The IP may differ depending on your network.
Viewing Raw Inference Results
As mentioned above, the prefix n02124075 is the ImageNet class ID.
The parameter result_topic:='/inference_result' specifies the ROS 2 topic where the inference results are published. You can view these results by running:
data: n02124075 Egyptian cat
- The message type is
std_msgs/msg/String. - Press Ctrl + C in the terminal to stop the running inference node.
To test with another image, simply update the img_path parameter. The web interface will automatically refresh with the new inference result.
Video Stream Inference
# Load ROS2 environment
Start the USB Camera
Option 1: Inference with Web Visualization
Terminal 1 — Run inference:
publish_result_img:='true' \
Terminal 2 — Start WebSocket visualization:
Terminal Output Example:
Option 2: Inference without Visualization (Data Only)
If you only want the raw inference results, run:
publish_result_img:='false' \
Print /inference_result topic:
data: n03788365 mosquito net
The message format is the standard ROS 2 string: std_msgs/msg/String.
infer_video.launch.py Parameters
| Parameter Name | Description | Default Value |
config_path | Path to the model configuration file for inference | config/detection/yolov6.yaml |
sub_image_topic | Image topic to subscribe to | /image_raw |
publish_result_img | Whether to publish the rendered inference image | false |
result_img_topic | Image topic to publish (only when publish_result_img=true) | /result_img |
result_topic | Inference-result topic to publish | /inference_result |
