UNet
UNet Overview
This guide demonstrates efficient image segmentation using the lightweight UNet semantic segmentation model with the SpacemiT AI processor.
The model accepts static images or video streams as input and outputs pixel-level semantic labels (grayscale) and pseudo-color renderings, which are published via ROS 2 for downstream perception or control modules.
The model is trained on the Cityscapes dataset and deployed in ONNX format, supporting accurate segmentation of typical urban scene elements such as people, vehicles, roads, and traffic signs.
Typical applications for UNet include:
  • Autonomous driving perception (road/target segmentation)
  • Urban street scene analysis and digital map construction
  • Remote sensing land-use and object classification
  • Medical image segmentation (e.g., organs or lesions)
  • Industrial defect detection and preprocessing
Install Dependencies
Load ROS 2 Environment
Check Supported Segmentation Models
Run the following command to view available segmentation model configurations:
ros2 launch br_perception infer_info.launch.py | grep 'segmentation'
Image Inference
Prepare Input Image
cp /opt/bros/humble/share/jobot_infer_py/data/segmentation/test_unet.jpg .
Run Inference and Save Results
config_path:='config/segmentation/unet.yaml' \
img_path:='./test_unet.jpg'
Example terminal output:
[INFO] [launch]: All log files can be found below /home/zq-pi/.ros/log/2025-05-26-09-45-18-005008-spacemit-k1-x-MUSE-Pi-board-5995
[INFO] [infer_img_node-1]: process started with pid [5996]
[infer_img_node-1] Inference time: 4665.87 ms
[infer_img_node-1] The semantic segmentation results are saved in: seg_result.jpg
[infer_img_node-1] The semantic segmentation pseudo-color image is saved to seg_pseudo_color.png
[INFO] [infer_img_node-1]: process has finished cleanly [pid 5996]
Output files:
  • seg_result.jpg: Overlay of input image with predicted segmentation
  • seg_pseudo_color.png: Pseudo-color map with semantic classes in color
Example images:
Original ImageSegmentation OverlayPseudo-Color Map
Web Visualization of Inference
Terminal 1 — Launch inference with image publishing:
img_path:='./test_unet.jpg' \
[INFO] [launch]: All log files can be found below /home/zq-pi/.ros/log/2025-05-26-10-05-41-203368-spacemit-k1-x-MUSE-Pi-board-7077
[INFO] [infer_img_node-1]: process started with pid [7084]
[infer_img_node-1] Inference time: 4712.77 ms
Terminal 2 — Start WebSocket visualization:
Visit the provided URL in your browser (http://<IP>:8080) to view the segmentation results.
Message Subscription and Monitoring
The topic result_topic:='/inference_result' publishes the inference results. You can view the data using:
header:
stamp:
sec: 0
nanosec: 0
frame_id: ''
height: 480
width: 640
encoding: mono8
is_bigendian: 0
step: 640
data:
- 2
- 2
- 2
- 2
The message uses the standard Image format. The encoding is mono8, representing a single-channel grayscale image, where each pixel value corresponds to the class index of the segmented object.
Press Ctrl + C to stop the following command:
ros2 launch br_perception infer_img.launch.py config_path:='config/segmentation/unet.yaml' img_path:='./test_unet.jpg' publish_result_img:=true result_img_topic:='result_img' result_topic:='/inference_result'
You can replace img_path with a different image to perform inference on other inputs. The results on the web interface will update automatically.
infer_img.launch.py Parameters
ParameterDescriptionDefault
config_pathPath to the model configuration file used for inferenceconfig/detection/yolov6.yaml
img_pathPath to the image file to run inference ondata/detection/test.jpg
publish_result_imgWhether to publish the detection result as an image messagefalse
result_img_topicTopic name for rendered image output (only valid if publish_result_img = true)/result_img
result_topicTopic name for the inference result message/inference_result
Video Stream Inference
Start Camera Device
Start Video Segmentation
Terminal 1 — Launch video stream segmentation:
Web Visualization
Visit http://<IP>:8080 in your browser to view real-time segmentation.
Raw Inference Results (No Visualization)
To have the grayscale semantic labels without web visualization:
header:
stamp:
sec: 0
nanosec: 0
frame_id: ''
height: 480
width: 640
encoding: mono8
is_bigendian: 0
step: 640
data:
- 2
- 2
- 2
- 2
infer_video.launch.py Parameters
Parameter NameDescriptionDefault Value
config_pathPath to the model configuration file for inferenceconfig/detection/yolov6.yaml
sub_image_topicImage topic to subscribe to/image_raw
publish_result_imgWhether to publish the rendered inference imagefalse
result_img_topicImage topic to publish (only when publish_result_img=true)/result_img
result_topicInference-result topic to publish/inference_result
