LLM 模型聊天
本模块基于本地部署的大语言模型(LLM, Large Language Model),实现自然语言处理对话能力,支持非流式服务与流式 Action 两种交互模式。
本模块可广泛应用于以下场景:
  • 人机自然语言交互
  • 智能问答与知识查询
  • 多轮对话状态管理
  • 指令意图理解与生成
安装系统依赖
运行环境配置与依赖安装
# 安装 LLM 模型运行环境(含模型下载与配置)
bash /opt/bros/humble/share/rdk_chat/llm_setup.sh
# 创建并激活 Python 虚拟环境
pip config set global.index-url https://mirrors.aliyun.com/pypi/simple/
python3 -m venv ~/ai_env
source ~/ai_env/bin/activate
# 安装 Python 依赖
pip install -r /opt/bros/humble/share/rdk_chat/requirements.txt
非流式聊天服务接口
导入环境
export PYTHONPATH=~/ai_env/lib/python3.12/site-packages/:$PYTHONPATH
启动服务端
ros2 launch rdk_chat chat_service.launch.py
默认服务名为:chat_service,服务类型为 jobot_interfaces/srv/LLMChat
客户端调用示例
新建 llm_client.py 文件:
from jobot_interfaces.srv import LLMChat
class LLMClientNode(Node):
super().__init__('llm_client')
self.cli = self.create_client(LLMChat, 'chat_service')
self.get_logger().info('等待 LLM 服务中...')
self.req = LLMChat.Request()
def send_request(self, prompt_text):
self.req.prompt = prompt_text
future = self.cli.call_async(self.req)
return future
node = LLMClientNode()
future = node.send_request("你好,告诉我什么是 ROS2?")
rclpy.spin_until_future_complete(node, future)
print("模型回复:", future.result().response)
node.get_logger().error('调用服务失败')
执行:
python3 llm_client.py
模型回复: Hello! ROS (Robot Operating System) is a set of development tools and runtime environment developed by the ROS Core Team. It provides complete system for building real-time autonomous robots.
It consists of three main components: **Core**, **Dynamic** and **Toolbox**.
- The core includes fundamental systems like sensor abstraction, command line interface, communication protocol handling, etc.
- Dynamic component is responsible to control robot execution based on user input
- Toolbox provides a set of tools for building custom modules or applications with the help of ROS.
With ROS2 you can create robots that have self-awareness and autonomous decision-making capabilities. It also has libraries like **Bullet**, which are used by ROS to simulate real-time systems, etc.
Is there anything else I should know about it?
流式聊天 Action 接口
支持实时响应输出的 LLM 聊天动作,适用于语音或多轮交互响应流式推送场景。
导入环境
启动 Action 服务端
ros2 launch rdk_chat chat_action.launch.py
默认 Action 名称为 chat_action,类型为 jobot_interfaces/action/LLMChatAction
客户端调用示例
新建 llm_client_action.py 文件:
from rclpy.action import ActionClient
from jobot_interfaces.action import LLMChatAction
class LLMChatClient(Node):
super().__init__('llm_chat_client')
self._action_client = ActionClient(self, LLMChatAction, 'chat_action')
def send_prompt(self, prompt):
goal_msg = LLMChatAction.Goal()
goal_msg.prompt = prompt
self._action_client.wait_for_server()
self._send_goal_future = self._action_client.send_goal_async(
goal_msg,
feedback_callback=self.feedback_callback
self._send_goal_future.add_done_callback(self.goal_response_callback)
def feedback_callback(self, feedback_msg):
feedback = feedback_msg.feedback
print(f'{feedback.partial}', end='', flush=True)
def goal_response_callback(self, future):
goal_handle = future.result()
if not goal_handle.accepted:
self.get_logger().info('目标被拒绝')
return
self.get_logger().info('目标已被接受')
self._get_result_future = goal_handle.get_result_async()
self._get_result_future.add_done_callback(self.result_callback)
def result_callback(self, future):
result = future.result().result
print(f'\n\n[Result] {result.response}')
client = LLMChatClient()
import sys
if len(sys.argv) > 1:
prompt = ' '.join(sys.argv[1:])
prompt = "你好,请介绍一下你自己"
client.send_prompt(prompt)
rclpy.spin(client)
执行:
python3 llm_client_action.py
终端输出示例:
[INFO] [1748593600.839893117] [llm_chat_client]: 目标已被接受
我是由阿里云开发的大规模多语言模型,可以提供各种类型的信息和解答您的问题,如新闻、财经资讯、科技知识等。如果您有任何具体的问题或需要帮助的事项,请随时告诉我!
[Result] 我是由阿里云开发的大规模多语言模型,可以提供各种类型的信息和解答您的问题,如新闻、财经资讯、科技知识等。如果您有任何具体的问题或需要帮助的事项,请随时告诉我!
总结对比
模式接口类型优点场景
非流式服务Service简单易用,响应完整问答类应用、任务调用
流式输出Action实时反馈,适配语音交互与长文本生成多轮对话、语音播报等流式交互
