LLM Chat Module
This module enables natural language conversation using a locally deployed Large Language Model (LLM).
It supports two modes of interaction:
- Non-streaming service
- Streaming Action
Typical application scenarios include:
- Human-machine natural language interaction
- Intelligent Q&A and knowledge query
- Multi-turn dialogue state management
- Command intent understanding and generation
Install System Dependencies
Runtime Environment Configuration & Dependency Installation
# Install LLM model runtime environment (includes model download and configuration)
bash /opt/bros/humble/share/br_chat/llm_setup.sh
# Create and activate Python virtual environment
python3 -m venv ~/ai_env
source ~/ai_env/bin/activate
# Install Python dependencies
pip install -r /opt/bros/humble/share/br_chat/requirements.txt
Non-Streaming Chat Service
Import Environment
export PYTHONPATH=~/ai_env/lib/python3.12/site-packages/:$PYTHONPATH
Start the Server
ros2 launch br_chat chat_service.launch.py
- Service name:
chat_service - Service type:
jobot_ai_msgs/srv/LLMChat
Client Call Example
Create a new file named llm_client.py:
from jobot_ai_msgs.srv import LLMChat
class LLMClientNode(Node):
super().__init__('llm_client')
self.cli = self.create_client(LLMChat, 'chat_service')
self.get_logger().info('Waiting for LLM service...')
self.req = LLMChat.Request()
def send_request(self, prompt_text):
self.req.prompt = prompt_text
future = self.cli.call_async(self.req)
return future
node = LLMClientNode()
future = node.send_request("Hello, tell me what ROS2 is?")
rclpy.spin_until_future_complete(node, future)
print("Model response:", future.result().response)
node.get_logger().error('Service call failed')
Run:
python3 llm_client.py
Model response: Hello! ROS (Robot Operating System) is a set of development tools and runtime environment developed by the ROS Core Team. It provides complete system for building real-time autonomous robots.
It consists of three main components: **Core**, **Dynamic** and **Toolbox**.
- The core includes fundamental systems like sensor abstraction, command line interface, communication protocol handling, etc.
- Dynamic component is responsible to control robot execution based on user input
- Toolbox provides a set of tools for building custom modules or applications with the help of ROS.
With ROS2 you can create robots that have self-awareness and autonomous decision-making capabilities. It also has libraries like **Bullet**, which are used by ROS to simulate real-time systems, etc.
Is there anything else I should know about it?
Streaming Chat Action
Supports real-time, streaming-response LLM chat actions, ideal for voice or multi-turn interactive scenarios that require incremental output.
Import Environment
Start the Action Server
ros2 launch br_chat chat_action.launch.py
By default
- Action name:
chat_action - Action type:
jobot_ai_msgs/action/LLMChatAction
Client Call Example
Create a new llm_client_action.py file:
from rclpy.action import ActionClient
from jobot_ai_msgs.action import LLMChatAction
class LLMChatClient(Node):
super().__init__('llm_chat_client')
self._action_client = ActionClient(self, LLMChatAction, 'chat_action')
def send_prompt(self, prompt):
goal_msg = LLMChatAction.Goal()
goal_msg.prompt = prompt
self._action_client.wait_for_server()
self._send_goal_future = self._action_client.send_goal_async(
goal_msg,
feedback_callback=self.feedback_callback
self._send_goal_future.add_done_callback(self.goal_response_callback)
def feedback_callback(self, feedback_msg):
feedback = feedback_msg.feedback
print(f'{feedback.partial}', end='', flush=True)
def goal_response_callback(self, future):
goal_handle = future.result()
if not goal_handle.accepted:
self.get_logger().info('Goal rejected')
return
self.get_logger().info('Goal accepted')
self._get_result_future = goal_handle.get_result_async()
self._get_result_future.add_done_callback(self.result_callback)
def result_callback(self, future):
result = future.result().result
print(f'\n\n[Result] {result.response}')
client = LLMChatClient()
import sys
if len(sys.argv) > 1:
prompt = ' '.join(sys.argv[1:])
prompt = "Hello, please introduce yourself"
client.send_prompt(prompt)
rclpy.spin(client)
Run:
python3 llm_client_action.py
Example terminal output:
[INFO] [1748593600.839893117] [llm_chat_client]: Goal accepted
I am a large-scale multilingual model developed by Alibaba Cloud. I can provide various types of information and answer your questions—such as news, financial updates, tech knowledge, and more. If you have any specific questions or need help with anything, feel free to let me know!
[Result] I am a large-scale multilingual model developed by Alibaba Cloud. I can provide various types of information and answer your questions—such as news, financial updates, tech knowledge, and more. If you have any specific
Summary
| Mode | Interface Type | Advantages | Use Cases |
| Non-streaming | Service | Easy to implement, complete response | Q&A applications, task calls |
| Streaming Output | Action | Real-time feedback, suitable for voice interaction and long text generation | Multi-turn dialogues, voice broadcasting and other streaming interactions |
