5.2.1 Ultralytics Usage Guide
Ultralytics is a company focused on computer vision and deep learning, best known as a key developer and maintainer of the famous YOLO (You Only Look Once) series of object detection models. The name refers to both the team and their open-source Python library.
Core Product Ultralytics YOLO: A top open-source solution for object detection and image segmentation, supporting YOLOv3/v5/v8/v9/v11.
Main Features
- Object Detection: Identifies and locates objects in images or videos.
- Segmentation: Segments objects at the pixel level.
- Pose Estimation: Detects human keypoints.
- Classification: Performs image classification tasks.
Ecosystem Features
- Pure Python implementation based on PyTorch.
- Easy installation via
pip install ultralytics. - Includes command-line tools and Python API out of the box.
- Offers training, validation, inference, and export tools.
- Supports deployment multiple formats like ONNX, TensorRT, CoreML, and OpenVINO (use ONNX for SpacemiT RISC-V).
More about Ultralytics, please visit Ultralytics Official Page
Application Areas
- Video surveillance and security
- Autonomous driving and traffic analysis
- Industrial inspection and robot vision
- Medical image analysis
- Smart retail
Framework Adaptation Notes
Ultralytics uses PyTorch as its backend framework. Note: PyTorch currently does not leverage hardware acceleration on SpacemiT RISC-V platforms.
- You can use Ultralytics on our platform for quick algorithm validation and prototyping.
- For deployment with hardware acceleration, use the
spacemit-ortframework. - Refer to the Demo Zoo and Model Quantization Guide for details on optimized deployment.
Install Dependencies
sudo apt install python3-pip python3-venv libxrender1 libgl1 libglib2.0-0t64
Platform Requirements
SpacemiT RISC-V Board: Must have the Bianbu ROS system image flashed.
Installing Ultralytics
Set Up Sources
pip config set global.index-url https://mirrors.aliyun.com/pypi/simple/
Create and Activate a Virtual Environment
python3 -m venv test1
source test1/bin/activate
pip install pip -U
Install Ultralytics
pip install --prefer-binary ultralytics
Expected output after installation:
Test the Installation
Sample Code Source: https://docs.ultralytics.com/zh/modes/predict/#plotting-results
Note: This example involves visualization. Please connect an HDMI screen, keyboard, and mouse to the board to run the commands locally.
Create a file named
demo1.pywith the following content:from PIL import Image
from ultralytics import YOLO
# Load a pretrained YOLO11n model
model = YOLO("yolo11n.pt")
# Run inference on 'bus.jpg'
results = model(["https://ultralytics.com/images/bus.jpg", "https://ultralytics.com/images/zidane.jpg"]) # results list
# Visualize the results
for i, r in enumerate(results):
# Plot results image
im_bgr = r.plot() # BGR-order numpy array
im_rgb = Image.fromarray(im_bgr[..., ::-1]) # RGB-order PIL image
# Show results to screen (in supported environments)
r.show()
# Save results to disk
r.save(filename=f"results{i}.jpg") -
Run:
python demo1.py -
Expected Output:
