3.2.1 Audio Capture with USB Microphone
This guide shows how to set up a USB microphone on your SpacemiT development board, install the required runtime environment, and capture audio using a Python example program.
Clone Repository
Clone the example code repository and navigate to the NLP example directory:
cd spacemit-demo/examples/NLP
Install Runtime Environment
Install required system packages, create a Python virtual environment, and install Python dependencies:
sudo apt install libportaudio2 libopenblas-dev python3-venv python3-pip
python3 -m venv .venv
source .venv/bin/activate
Start Audio Capture Program
Run the following command to start the audio capture program:
python 02_capture_audio.py
- Press Enter to begin audio capture.
- Maximum capture duration per session is 4 seconds.
- The recorded audio file is saved as
record.pcm.
