YOLO
YOLO Model Overview
This example shows how to run YOLO-series object-detection inference on SpacemiT NPU, using either images or a live video stream as input, and then publish the results (object classes + bounding-box coordinates) via ROS 2.
Supported Model Versions
  • YOLOv5
  • YOLOv6
  • YOLOv8
  • YOLOv11 (and others)
ONNX models can be downloaded from ⭐ Bianbu AI Demo Zoo All models are trained on the COCO dataset and can recognize 80 common object classes (people, animals, fruits, vehicles, etc.).
Advantages
  • Fast inference
  • High accuracy & generalization
  • Easy deployment, low resource usage
Use-Cases
  • Autonomous driving – pedestrian & vehicle detection
  • Smart home – garbage classification, surveillance
  • Smart security – abnomaly detection, fall detection
Platform Requirements
SpacemiT RISC-V:
  • Pre-flashed with the Bianbu ROS system image
Install Dependencies
Run the following command to install required libraries and tools:
Import ROS 2 Environment
Set up your ROS 2 environment:
Model Configuration Check
Run the following command to list the model configurations currently supported on your system:
ros2 launch br_perception infer_info.launch.py | grep 'detection'
Sample output:
During subsequent inference, set config_path to one of these .yaml files to select the desired YOLO model.
Running Inference on an Image
Prepare the Image
Copy a test image to your current folder:
Save Inference Results Locally
config_path:='config/detection/yolov6.yaml' \
img_path:='./test.jpg'
The processed output will be saved as det_result.jpg in your specified output directory.
Viewing Inference Results in a Web Browser
Launch Inference Server in Terminal 1:
img_path:='./test.jpg' \
Launch the web visualization tool in a new Terminal 2:
The terminal will prompt the browser address:
Open a browser and visit http://<IP>:8080 to see annotated results live.
Message Subscription and Monitoring
Check Topic Data
Inference results are published to the /inference_result topic. Use the following commands to monitor the output:
header:
stamp:
sec: 1745571001
nanosec: 597668762
frame_id: camera_link
results:
- x_min: 109
y_min: 99
width: 149
height: 316
label: bottle
conf: 0.4000000059604645
- x_min: 270
y_min: 209
width: 150
height: 249
label: bottle
- x_min: -1
y_min: 424
width: 326
height: 55
label: sink
conf: 0.30000001192092896
Check Message Format Definitions
ros2 interface show jobot_ai_msgs/msg/DetectionResultArray
Message Structure Example:
std_msgs/Header header
builtin_interfaces/Time stamp
int32 sec
uint32 nanosec
string frame_id
jobot_ai_msgs/DetectionResult[] results
int32 x_min
int32 y_min
int32 width
int32 height
string label
float32 conf
Python Subscription Example
from jobot_ai_msgs.msg import DetectionResultArray, DetectionResult
'/detections',
for det in msg.results:
node = DetectionSubscriber()
infer_img.launch.py Parameters
ParameterDescriptionDefault
config_pathPath to the model configuration file used for inferenceconfig/detection/yolov6.yaml
img_pathPath to the image file to run inference ondata/detection/test.jpg
publish_result_imgWhether to publish the detection result as an image messagefalse
result_img_topicTopic name for rendered image output (only valid if publish_result_img = true)/result_img
result_topicTopic name for the inference result message/inference_result
Video Stream Inference
Start the Camera (USB Example)
Option 1: Inference with Web Visualization
Terminal 1 — Run inference:
Terminal 2 — Start WebSocket visualization:
Terminal prompts access address:
Please visit in your browser http://<IP>:8080
Open a browser at http://<IP>:8080 to view the inference results in real time:
Option 2: Inference without Visualization (Data Only)
To obtain raw inference results without visualization, execute:
Obtain data through the ros2 topic echo /inference_result topic.
Message Subscription and Viewing
Print /inference_result topic data
header:
stamp:
sec: 1745571001
nanosec: 597668762
results:
- x_min: 109
y_min: 99
width: 149
height: 316
label: bottle
- x_min: 270
y_min: 209
width: 150
height: 249
label: bottle
- x_min: -1
y_min: 424
width: 326
height: 55
label: sink
To check message format:
Structure:
bianbu@bianbu:~$ ros2 interface show jobot_ai_msgs/msg/DetectionResultArray
int32 sec
uint32 nanosec
string frame_id
int32 x_min
int32 y_min
int32 width
int32 height
string label
float32 conf
'/inference_result',
infer_video.launch.py Parameters
Parameter NameDescriptionDefault Value
config_pathPath to the model configuration file for inferenceconfig/detection/yolov6.yaml
sub_image_topicImage topic to subscribe to/image_raw
publish_result_imgWhether to publish the rendered inference imagefalse
result_img_topicImage topic to publish (only when publish_result_img=true)/result_img
result_topicInference-result topic to publish/inference_result
