6.5.5 Wheeltec ROS Differential Drive Robot Adaptation
Last Version: 19/09/2025
This demo showcases how to integrate the K1 Board with the Wheeltec ROS Differential Drive Robot.
A complete ROS robot system usually includes four core parts:
- Motion Chassis (Execution)
- ROS Master (Decision-Making)
- Sensors (Perception)
- Battery (Power Source)
The Battery Module is built into the Chassis Module and provides power to all other modules via electrical wiring. Data communication between the Chassis Module, ROS Master Module, and Sensor Modules is also handled through electrical connections.
This case shows how to use the K1 Board as the ROS Master controller for the Wheeltec differential drive robot and implement motion control.
Hareware
- 1 × Spacemit K1 Board
- 1 × Wheeltec ROS Differential Drive Robot
K1 Development Board
Hardware Specifications
The K1 development board integrates an 8-core RISC-V processor, storage, general-purpose interfaces, and expansion ports on a single PCB. It supports UEFI boot and can run various operating systems and applications, making it a complete computer system.
This example shows how to replace the Raspberry Pi on the Wheeltec robot with the K1 board as the ROS master.
- Power: Can be supplied via the Type-C port on the motion chassis (STM32) controller (5V) or directly from the battery (12V).
- Signals: All sensor connections (motion chassis, LiDAR, camera) to the K1 board are made via USB interfaces.
All sensors on the Wheeltec ROS Drive robot connect to the K1 board, with specific integration methods detailed in the sections below.
Motion Chassis (Wheeltec STM32 Controller)
Hardware Specifications The Wheeltec Educational ROS Differential Drive Robot uses an STM32 all-in-one control board as its chassis.
- Power Supply: Sourced from the battery, distributed to other components via T-cables or splitter cables.
- Signals: Originate from the K1 board, connected via dedicated cables to control motor and wheel movement.
Adaptation Procedure
Connect the chassis power cable (TypeC-to-TypeC) to the K1 board.
Turn on the chassis power switch and wait for the K1-Bianbu-desktop system to boot.
Connect the chassis signal cable (TypeC-to-USB) to the K1 board.
Open a new terminal on the K1 board and run:
sudo dmesg | tail -20
Look for output like this to confirm the chassis USB port (e.g.,
/dev/ttyACM0
):[ 1673.471036] usb 2-1.1: new full-speed USB device number 8 using xhci-hcd
[ 1673.675568] cdc_acm 2-1.1:1.0: ttyACM0: USB ACM device -
Based on your port number, check device details:
udevadm info -a -n /dev/ttyACM0
Look for output like this to have the
ATTRS{serial}
attributeATTRS{product}=="USB Single Serial"
ATTRS{serial}=="0002"
ATTRS{serial}=="xhci-hcd.0.auto" -
Remap the chassis Udev rule to fix the USB serial device name:
echo 'SUBSYSTEM=="tty", ATTRS{serial}=="0002", MODE:="0777",SYMLINK+="wheeltec_controller"' | sudo tee /etc/udev/rules.d/wheeltec_controller.rules
Reload the udev rules to apply the change:
sudo udevadm trigger
Test Operation
One a terminal (Terminal 1), compile and test the Wheeltec-provided ROS 2 chassis package : Note: Comment out the line
<depend>ackermann_msgs</depend>
in theturn_on_wheeltec_robot/package.xml
file before building.sudo apt update
sudo apt install ros-humble-turtlesim ros-humble-navigation2 ros-humble-joint-state-publisher ros-humble-robot-localization teleop_twist_keyboard
colcon build --packages-select serial turn_on_wheeltec_robot wheeltec_robot_msg wheeltec_robot_urdf
ros2 launch turn_on_wheeltec_robot turn_on_wheeltec_robot.launch.py -
On a new terminal (Terminal 2), start the keyboard control node:
You can now control the robot's movement using the keyboard keys as displayed in the terminal.
LiDAR (Leishen M10P)
Hardware Specifications The Wheeltec ROS Differential Drive Robot uses a Leishen Intelligent M10P LiDAR.
- Power & Signals: Connected to the K1 board via a USB interface.
Connect the LiDAR data cable (TypeC-to-USB) to the K1 board.
Open a new terminal and run:
Look for output like this to confirm the LiDAR USB port (e.g.,
/dev/ttyACM1
):[ 4562.938371] usb 2-1.3: new full-speed USB device number 9 using xhci-hcd
[ 4563.146987] cdc_acm 2-1.3:1.0: ttyACM1: USB ACM device -
udevadm info -a -n /dev/ttyACM1
ATTRS{serial}
:ATTRS{product}=="USB Single Serial"
ATTRS{serial}=="5A6D016420"
Remap the LiDAR Udev rule to fix the USB serial device name:
echo 'SUBSYSTEM=="tty", ATTRS{serial}=="5A6D016420", MODE:="0777",SYMLINK+="wheeltec_lidar"' | sudo tee /etc/udev/rules.d/wheeltec_lidar.rules
Test Operation
Compile and test the Wheeltec-provided LiDAR ROS 2 package:
colcon build --packages-select wheeltec_lidar_ros2
ros2 launch lslidar_driver lsm10p_uart_launch.py -
On a PC in the same network, use RViz2 to view LiDAR data:
Open a terminal (Terminal 1) and publish a static transform for the LiDAR:
ros2 run tf2_ros static_transform_publisher 0 0 0 0 0 0 base_link laser
Open another terminal (Terminal 2) and launch RViz2:
ros2 run rviz2 rviz2
In RViz2, set the Fixed Frame to
laser
, click Add > By Topic >/scan
, and click OK. You should see LiDAR data like this:
Camera (C70 RGB Camera)
Hardware Specifications The Wheeltec robot uses a C70 monocular RGB camera.
Connect the camera to the K1 board’s USB port.
v4l2-ctl --list-devices
Look for output like this to confirm the camera USB port (e.g.,
/dev/video20
):Integrated Webcam: Integrated W (usb-xhci-hcd.0.auto-1.4):
/dev/video20
/dev/video21
/dev/media1
Test Operation
Install the USB camera package on a terminal (Terminal 1):
sudo apt install ros-humble-usb-cam
ros2 run usb_cam usb_cam_node_exe --ros-args -p video_device:=/dev/video20 -
Open a new terminal (Terminal 2) to view the image topic output:
ros2 topic echo /image_raw
Alternatively, on a PC in the same network, view the live feed:
