YOLO-World 物体检测
YOLO-World 模型简介
YOLO-World 是腾讯 AI Lab(AI 实验室)提出的一种实时 开放词汇(Open-Vocabulary)零样本物体检测 模型,首次发表于 2024 年初,它基于快速高效的 YOLO 系列(尤其是 Ultralytics 的 YOLOv8)架构,并结合了视觉–语言(Vision-Language)融合技术,实现无需针对每个类别单独训练即可检测任意描述的对象
本示例展示如何基于 SpacemiT 智算核,使用图片或视频流作为输入,执行 YOLO-World 模型的推理,并通过 ROS 2 发布检测结果。
安装依赖
sudo apt install python3-venv python3-pip ros-humble-camera-info-manager \
导入 ROS2 环境
准备虚拟环境
python3 -m venv ~/test3
source ~/test3/bin/activate
pip install -r /opt/bros/humble/share/jobot_yolo_world/data/requirements.txt
export PYTHONPATH="$HOME/test3/lib/python3.12/site-packages":$PYTHONPATH
准备图片
cp /opt/bros/humble/share/jobot_yolo_world/data/test2.jpg .
本地保存推理结果
ros2 launch rdk_perception yoloworld_infer_img.launch.py \
img_path:='./test2.jpg' \
class_names:="[fan, box]"
输出结果将保存在当前目录的 yoloworld_result.jpg 中,如图所示。
(test3) bianbu@bianbu:~$ ros2 launch rdk_perception yoloworld_infer_img.launch.py   img_path:='./test2.jpg' class_names:="[fan, box]"
[INFO] [launch]: All log files can be found below /home/bianbu/.ros/log/2025-08-13-16-09-04-608187-bianbu-217760
[INFO] [yoloworld_img_node-1]: process started with pid [217761]
[yoloworld_img_node-1] /home/bianbu/test3/lib/python3.12/site-packages/clip/clip.py:6: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
[yoloworld_img_node-1] from pkg_resources import packaging
[yoloworld_img_node-1] All model files already exist and do not need to be downloaded
[yoloworld_img_node-1] conf_threshold: 0.2, iou_threshold: 0.45, class_names: ['fan', 'box']
[yoloworld_img_node-1] Init Model ..................
[yoloworld_img_node-1] all time cost:0.697995662689209
[yoloworld_img_node-1] x_min:980, y_min:469, width:466, height:424, label:box, confidence:0.72
[yoloworld_img_node-1] x_min:417, y_min:510, width:294, height:493, label:fan, confidence:0.29
[yoloworld_img_node-1] The object detection results are saved in: det_result.jpg
[INFO] [yoloworld_img_node-1]: process has finished cleanly [pid 217761]
启动推理发布节点(终端 1):
启动 Web 可视化服务(终端 2):
ros2 launch rdk_visualization websocket_cpp.launch.py image_topic:='/result_img'
终端提示访问地址:
还可以通过追加 port:=xxxx 参数来指定端口号,以避免端口冲突
结果订阅
输入 ros2 topic echo /inference_result 查看推理结果话题
使用以下代码实现简单的话题订阅
from jobot_interfaces.msg import DetectionResultArray, DetectionResult
'/inference_result',
for det in msg.results:
node = DetectionSubscriber()
yoloworld_infer_img.launch.py 的参数说明
conf_threshold控制检测结果可信度的最低标准(过滤低分框)0.2
iou_threshold控制去重规则的严格程度(处理重叠框)0.45
class_names控制检测目标的范围(可以是常规类别,也可以是自然语言描述)"[people]"
启动相机(USB 示例)
ros2 launch rdk_sensors usb_cam.launch.py video_device:="/dev/video20"
启动推理并发布结果
启动推理(终端 1):
ros2 launch rdk_perception yoloworld_infer_video.launch.py \
result_topic:='/inference_result' \
class_names:="[box]"
Web 显示(终端 2):
终端提示访问地址:
无可视化(仅数据输出)
如果你只想要拿到模型推理的结果,运行下述命令:
结果订阅
使用以下代码实现简单的话题订阅
yoloworld_infer_video.launch.py 的参数说明
