6.5.2 Smart Retail with Robotic Arm
Last Version: 19/09/2025
Watch the Demo Video
This demo showcases the K1 platform controls an Elephant robotic arm for a smart retail scenario. It integrates:
  • Function Call LLM
  • YOLOv8 for product detection
  • OCR for barcode and payment recognition
The robotic arm accurately identifies products through object detection and uses OCR for barcode scanning and checkout, providing an efficient and intelligent shopping experience.
The system supports voice interaction, significantly enhancing automation and convenience in shopping, and demonstrates the future intelligent retail.
Hardware
  • 1 × Development board with K1 SoC (with power supply)
  • 1 × Elephant Robotics myCobot 280 robotic arm (with flange camera and vacuum pump)
  • 1 × Elephant Aikits AI kit
  • 1 × USB microphone
  • 1 × USB sound card or speaker
Software Modules
This demo consists of the following core modules:
  • Smart Product Recognition Module
    • Combines voice interaction and computer vision.
    • Uses the Function Call large language model to interprets voice commands like "Pick up an orange".
    • Uses YOLOv8 to detect the target product in the camera feed.
    • Supports detection of multiple product categories and 2D image coordinates.
  • Robotic Arm Motion Control Module
    • Controls the robotic arm’s joints, angles, and suction pump.
    • Converts YOLOv8’s 2D image coordinates into 3D joint angles for precise movement.
  • Product Scanning Module
    • Uses the flange camera to scan product barcodes and retrieve pricing information.
  • Payment Processing Module
    • Uses the Paddle OCR engine to recognize payment vouchers.
Follow these steps to set up the environment for the smart retail system.
Step 1: Download the Project Code
Clone the project repository:
Step 2: Install System Dependencies
Update the system and install required libraries:
sudo apt install -y \
spacemit-ollama-toolkit \
libopenblas-dev \
python3-venv \
libceres-dev \
libopencv-dev
Step 3: Install Python Dependencies
  1. Create a Python virtual environment:
    virtualenv ~/asr-env
  2. Configure pip to use the Spacemit mirror source:
  3. Install project dependencies:
    cd ~/jobot-ai-elephant
    source ~/asr-env/bin/activate
Step 4: Download and Deploy LLMs to Ollama
  1. Create a directory for model storage:
    mkdir -p ~/models && cd ~/models
  2. Download the model and configuration files
    # Download the Qwen2.5 0.5B model
    wget -c https://archive.spacemit.com/spacemit-ai/gguf/Qwen2.5-0.5B-Instruct-Q4_0.gguf --no-check-certificate
    wget -c https://archive.spacemit.com/spacemit-ai/modelfile/qwen2.5:0.5b.modelfile --no-check-certificate
    # Download the Qwen2.5 0.5B-FC model
    wget -c https://archive.spacemit.com/spacemit-ai/gguf/qwen2.5-0.5b-f16-elephant-fc-Q4_0.gguf --no-check-certificate
    wget -c https://archive.spacemit.com/spacemit-ai/modelfile/qwen2.5-0.5b-elephant-fc.modelfile --no-check-certificate
  3. Deploy the models to Ollama:
    ollama create qwen2.5-0.5b-elephant-fc -f qwen2.5-0.5b-elephant-fc.modelfile
  4. Verify model deployment:
    ollama list
    Expected Output with both models listed, as shown below
    image-20250428153224566
  5. Remove the model storage directory to save space:
    rm -rf ~/models
Step 5: Set Audio Permissions
Run the following command to add the current user to the audio group, granting access to and management of audio devices:
Audio Module Configuration Guide
Step 1: Detect and Configure Microphone
List available microphone devices:
arecord -l
Sample Output:
card 1: Camera [USB Camera], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: Camera_1 [USB 2.0 Camera], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 3: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Note: Avoid selecting devices labeled "Camera" as they are typically camera microphones.
In this example, choose card 3 as the main microphone.
Update the microphone configuration in ~/jobot-ai-elephant/smart_main_asr.py:
record_device = 3  # Recording device index, should be modified according to the actual detection results
rec_audio = RecAudioThreadPipeLine(
vad_mode=1,
sld=2,
max_time=2,
channels=1,
rate=48000,
device_index=record_device
Step 2: Detect and Configure the Speaker
List available speaker devices:
aplay -l
Subdevices: 1/1
card 2: Device [USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Update the speaker configuration in the following files:
  • File 1: ~/jobot-ai-elephant/smart_main_asr.py
    play_device='plughw:2,0'  # Speaker sittings
  • File 2: ~/jobot-ai-elephant/spacemit_audio/play.py
Step 3: Configure Recording Parameters
Set the maximum recording duration in ~/jobot-ai-elephant/smart_main_asr.py:
rec_audio.max_time_record = 3  # Maximum recording time in seconds
Understand recording modes:
  • By default, non-blocking mode is used for recording
  • To wait for recording to complete, use the join() method
# Start recording
rec_audio.frame_is_append = True
rec_audio.start_recording()
rec_audio.thread.join() # Wait for recording to complete
Run the Program
source ~/asr_env/bin/activate
python smart_main_asr.py
Usage Instructions:
  • Press Enter directly to enter recording mode
  • Default recording duration is 3 seconds
  • Supports fuzzy command matching (e.g., "Grab an orange", "Grab an apple", "Checkout", etc.)
  • Natural language commands supported by the large language model, such as:
    • "Give me an apple", "One more orange", etc.
    • Can recognize various object names
