Bianbu 3.0 ROOTFS Creation
Environment Requirements
The host machine is recommended to be Ubuntu 20.04/22.04, with docker ce and qemu-user-static (8.0.4, customized version with Vector 1.0 support enabled by default) installed.
docker
Docker ce installation can refer to https://docs.docker.com/engine/install/.
qemu
Uninstall binfmt-support
The customized qemu-user-static conflicts with binfmt-support because binfmt-support provides
/etc/init.d/binfmt-supportwhich is a traditional SysVinit startup script, while the customized qemu-user-static provides/lib/systemd/system/systemd-binfmt.servicewhich is a systemd service unit file./etc/init.d/binfmt-supportexecutes later than/lib/systemd/system/systemd-binfmt.service, causing it to override systemd settings.sudo apt-get purge binfmt-support -
Download the customized qemu
wget https://archive.spacemit.com/qemu/qemu-user-static_8.0.4%2Bdfsg-1ubuntu3.23.10.1_amd64.deb -
Install the customized qemu
sudo dpkg -i qemu-user-static_8.0.4+dfsg-1ubuntu3.23.10.1_amd64.deb -
Register qemu-user-static to the kernel so that the entire system (including containers) can directly execute riscv binary files
sudo systemctl restart systemd-binfmt.service -
Verify if qemu-user-static registration is successful
wget https://archive.spacemit.com/qemu/rvv
chmod a+x rvv
./rvvThe following information indicates successful registration:
helloworld
spacemit
Prepare Base rootfs
Create working directory
mkdir ~/bianbu-workspace -
Create and start container
docker run --privileged -itd -v ~/bianbu-workspace:/mnt --name build-bianbu-rootfs harbor.spacemit.com/bianbu/bianbu:latest -
Enter container
docker exec -it -w /mnt build-bianbu-rootfs bash -
Install basic tools
apt-get update
apt-get -y install wget uuid-runtime -
Configure environment variables for convenience in subsequent commands
Version 3.0
export BASE_ROOTFS_URL=https://archive.spacemit.com/bianbu-base/bianbu-base-25.04.2-base-riscv64.tar.gz
export BASE_ROOTFS=$(basename "$BASE_ROOTFS_URL")
export TARGET_ROOTFS=rootfs
Download
wget $BASE_ROOTFS_URL -
Extract to specified directory
mkdir -p $TARGET_ROOTFS && tar -zxpf $BASE_ROOTFS -C $TARGET_ROOTFS -
Mount some system resources to rootfs
mount -t proc /proc $TARGET_ROOTFS/proc
mount -t sysfs /sys $TARGET_ROOTFS/sys
mount -o bind /dev $TARGET_ROOTFS/dev
mount -o bind /dev/pts $TARGET_ROOTFS/dev/pts
Essential Configuration
Configure Repository
First configure environment variables for convenience in subsequent commands
export REPO="archive.spacemit.com/bianbu" -
Configure bianbu.sources
Version 3.0
cat <<EOF | tee $TARGET_ROOTFS/etc/apt/sources.list.d/bianbu.sources
Types: deb
URIs: https://$REPO/
Suites: plucky/snapshots/v3.0 plucky-security/snapshots/v3.0 plucky-updates/snapshots/v3.0 plucky-porting/snapshots/v3.0 plucky-customization/snapshots/v3.0 bianbu-v3.0-updates
Components: main universe restricted multiverse
Signed-By: /usr/share/keyrings/bianbu-archive-keyring.gpg
EOF
Configure DNS
echo "nameserver 8.8.8.8" >$TARGET_ROOTFS/etc/resolv.conf
Install Hardware-Related Packages
chroot $TARGET_ROOTFS /bin/bash -c "apt-get update"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades upgrade"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install initramfs-tools"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-esos img-gpu-powervr k1x-vpu-firmware k1x-cam spacemit-uart-bt spacemit-modules-usrload opensbi-spacemit u-boot-spacemit linux-generic"
Install Meta Packages
Different variants have different meta packages:
- Minimal: bianbu-minimal
- GNOME Desktop Version: bianbu-desktop bianbu-desktop-zh bianbu-desktop-en bianbu-desktop-minimal-en bianbu-standard bianbu-development
- LXQt Desktop Version: bianbu-desktop-lite
GNOME, LXQt and NAS are all based on Minimal. It is recommended to install the Minimal meta package first, then install the corresponding meta package.
- Minimal variant:
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-minimal"
- GNOME Desktop variant:
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-desktop bianbu-desktop-zh bianbu-desktop-en bianbu-desktop-minimal-en bianbu-standard bianbu-development"
- LXQt Desktop variant:
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-desktop-lite"
Tip: After completing the installation of all packages, you can execute the following command to clean up the cache to reduce the final firmware size
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get clean"
General Configuration
Configure Locale
chroot $TARGET_ROOTFS /bin/bash -c "apt-get -y install locales"
chroot $TARGET_ROOTFS /bin/bash -c "echo \"locales locales/locales_to_be_generated multiselect en_US.UTF-8 UTF-8, zh_CN.UTF-8 UTF-8\" | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "echo \"locales locales/default_environment_locale select zh_CN.UTF-8\" | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "sed -i 's/^# zh_CN.UTF-8 UTF-8/zh_CN.UTF-8 UTF-8/' /etc/locale.gen"
chroot $TARGET_ROOTFS /bin/bash -c "dpkg-reconfigure --frontend=noninteractive locales"
Configure Timezone
chroot $TARGET_ROOTFS /bin/bash -c "echo 'tzdata tzdata/Areas select Asia' | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "echo 'tzdata tzdata/Zones/Asia select Shanghai' | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "rm /etc/timezone"
chroot $TARGET_ROOTFS /bin/bash -c "rm /etc/localtime"
chroot $TARGET_ROOTFS /bin/bash -c "dpkg-reconfigure --frontend=noninteractive tzdata"
Configure Time Server
sed -i 's/^#NTP=.*/NTP=ntp.aliyun.com/' $TARGET_ROOTFS/etc/systemd/timesyncd.conf
Configure Password
chroot $TARGET_ROOTFS /bin/bash -c "echo root:bianbu | chpasswd"
Configure Network
- Minimal
cat <<EOF | tee $TARGET_ROOTFS/etc/netplan/01-netcfg.yaml
network:
version: 2
renderer: networkd
ethernets:
end0:
dhcp4: true
dhcp-identifier: mac
end1:
dhcp4: true
EOF
chroot $TARGET_ROOTFS /bin/bash -c "chmod 600 /etc/netplan/01-netcfg.yaml"
- GNOME/LXQt Desktop Version
cat <<EOF | tee $TARGET_ROOTFS/etc/netplan/01-network-manager-all.yaml
# Let NetworkManager manage all devices on this system
network:
version: 2
renderer: NetworkManager
EOF
chroot $TARGET_ROOTFS /bin/bash -c "chmod 600 /etc/netplan/01-network-manager-all.yaml"
Note: Different variants only need to configure their respective files.
Generate Partition Images
Note: After installation and configuration are complete, unmount first!
mount | grep "$TARGET_ROOTFS/proc" > /dev/null && umount -l $TARGET_ROOTFS/proc
mount | grep "$TARGET_ROOTFS/sys" > /dev/null && umount -l $TARGET_ROOTFS/sys
mount | grep "$TARGET_ROOTFS/dev/pts" > /dev/null && umount -l $TARGET_ROOTFS/dev/pts
mount | grep "$TARGET_ROOTFS/dev" > /dev/null && umount -l $TARGET_ROOTFS/dev
Generate UUID and write to /etc/fstab
UUID_BOOTFS=$(uuidgen)
UUID_ROOTFS=$(uuidgen)
cat >$TARGET_ROOTFS/etc/fstab <<EOF
# <file system> <dir> <type> <options> <dump> <pass>
UUID=$UUID_ROOTFS / ext4 defaults,noatime,errors=remount-ro 0 1
UUID=$UUID_BOOTFS /boot ext4 defaults 0 2
EOF
Move boot to another directory to create bootfs and rootfs partitions separately
mkdir -p bootfs
mv $TARGET_ROOTFS/boot/* bootfs
Generate bootfs.ext4 and rootfs.ext4
mke2fs -d bootfs -L bootfs -t ext4 -U $UUID_BOOTFS bootfs.ext4 "256M"
mke2fs -d $TARGET_ROOTFS -L rootfs -t ext4 -N 524288 -U $UUID_ROOTFS rootfs.ext4 "2048M"
Note: Regarding rootfs.ext4 size. minimal recommends 2048M, bianbu gnome version recommends 8192M, bianbu lxqt version recommends 6144M
At this point, you can see two partition images in the current directory, bootfs.ext4 and rootfs.ext4, which can be flashed to the board using fastboot.
