Bianbu 1.0 ROOTFS Create
Environment Requirements
It is recommended to use Ubuntu 20.04/22.04 as the host system, with Docker CE and a customized version of qemu-user-static (version 8.0.4, with Vector 1.0 support enabled by default) installed.
Docker
For Docker CE installation, refer to https://docs.docker.com/engine/install/.
QEMU
Remove
binfmt-supportThe customized
qemu-user-staticconflicts withbinfmt-supportdue to:binfmt-supportuses a legacy SysVinit script:/etc/init.d/binfmt-support- The customized
qemu-user-staticrelies on a systemd unit:/lib/systemd/system/systemd-binfmt.service
Since the SysVinit script runs after the systemd service, it can override the systemd settings, causing conflicts.
To avoid this, remove
binfmt-support:sudo apt-get purge binfmt-support -
Download the customized qemu
wget https://archive.spacemit.com/qemu/qemu-user-static_8.0.4%2Bdfsg-1ubuntu3.23.10.1_amd64.deb -
Install the customized qemu
sudo dpkg -i qemu-user-static_8.0.4+dfsg-1ubuntu3.23.10.1_amd64.deb -
Register
qemu-user-staticwith the kernel, so the system (including containers) can directly execute RISC-V binaries:sudo systemctl restart systemd-binfmt.service -
Verify if
qemu-user-staticis registered successfullywget https://archive.spacemit.com/qemu/rvv
chmod a+x rvv
./rvvOutput like the following indicates success:
helloworld
spacemit
Prepare the Base RootFS
Create a working directory
mkdir ~/bianbu-workspace -
Create and start a container
docker run --privileged -itd -v ~/bianbu-workspace:/mnt --name build-bianbu-rootfs ubuntu:24.04 -
Enter the container
docker exec -it -w /mnt build-bianbu-rootfs bash -
Install basic tools
apt-get update
apt-get -y install wget uuid-runtime -
Set environment variables
export BASE_ROOTFS_URL=https://archive.spacemit.com/bianbu-base/bianbu-base-23.10-base-riscv64.tar.gz
export BASE_ROOTFS=$(basename "$BASE_ROOTFS_URL")
export TARGET_ROOTFS=rootfs -
Download the base rootfs
wget $BASE_ROOTFS_URL -
Extract to a specified directory
mkdir -p $TARGET_ROOTFS && tar -zxpf $BASE_ROOTFS -C $TARGET_ROOTFS -
Mount system resources into the rootfs
mount -t proc /proc $TARGET_ROOTFS/proc
mount -t sysfs /sys $TARGET_ROOTFS/sys
mount -o bind /dev $TARGET_ROOTFS/dev
mount -o bind /dev/pts $TARGET_ROOTFS/dev/pts
Essential Configuration
Configure the Source Repositories
export DIST=mantic
export REPO="archive.spacemit.com/bianbu-ports"
export VERSION="v1.0.13" -
Install the repository GPG keys
wget -O $TARGET_ROOTFS/usr/share/keyrings/bianbu-archive-keyring-mantic.gpg https://archive.spacemit.com/bianbu-ports/bianbu-archive-keyring.gpg
wget -O $TARGET_ROOTFS/etc/apt/trusted.gpg.d/bianbu-archive-keyring-mantic.gpg https://archive.spacemit.com/bianbu-ports/bianbu-archive-keyring.gpg -
Configure
sources.listcat <<EOF | tee $TARGET_ROOTFS/etc/apt/sources.list
# $DIST
deb [trusted=yes] https://$REPO/ $DIST/snapshots/$VERSION main universe multiverse restricted
# deb-src [trusted=yes] https://$REPO/ $DIST/snapshots/$VERSION main universe multiverse restricted
# $DIST-security
deb [trusted=yes] https://$REPO/ $DIST-security/snapshots/$VERSION main universe multiverse restricted
# deb-src [trusted=yes] https://$REPO/ $DIST-security/snapshots/$VERSION main universe multiverse restricted
EOF -
Configure
sources.list.d/bianbu.listcat <<EOF | tee $TARGET_ROOTFS/etc/apt/sources.list.d/bianbu.list
# $DIST-spacemit
deb [trusted=yes] https://$REPO/ $DIST-spacemit/snapshots/$VERSION main universe multiverse restricted
# deb-src [trusted=yes] https://$REPO/ $DIST-spacemit/snapshots/$VERSION main universe multiverse restricted
# $DIST-porting
deb [trusted=yes] https://$REPO/ $DIST-porting/snapshots/$VERSION main universe multiverse restricted
# deb-src [trusted=yes] https://$REPO/ $DIST-porting/snapshots/$VERSION main universe multiverse restricted
# $DIST-customization
deb [trusted=yes] https://$REPO/ $DIST-customization/snapshots/$VERSION main universe multiverse restricted
# deb-src [trusted=yes] https://$REPO/ $DIST-customization/snapshots/$VERSION main universe multiverse restricted
EOF -
Configure package source priority
cat <<EOF | tee $TARGET_ROOTFS/etc/apt/preferences.d/bianbu
Package: *
Pin: release o=Spacemit, n=mantic-spacemit
Pin-Priority: 1200
Package: *
Pin: release o=Spacemit, n=mantic-porting
Pin-Priority: 1100
Package: *
Pin: release o=Spacemit, n=mantic-customization
Pin-Priority: 1100
EOF
Configure DNS
echo "nameserver 8.8.8.8" >$TARGET_ROOTFS/etc/resolv.conf
Install Hardware-Related Packages
chroot $TARGET_ROOTFS /bin/bash -c "apt-get -y install ca-certificates"
chroot $TARGET_ROOTFS /bin/bash -c "apt-get update"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades upgrade"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install initramfs-tools"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-esos img-gpu-powervr k1x-vpu-firmware k1x-cam spacemit-uart-bt spacemit-modules-usrload opensbi-spacemit u-boot-spacemit linux-image-6.1.15"
Install Metapackages
Different variants have different metapackages:
- Minimal:
bianbu-minimal - Desktop:
bianbu-desktop,bianbu-desktop-zh,bianbu-desktop-en,bianbu-desktop-minimal-en,bianbu-standard,bianbu-development - NAS:
bianbu-nas
Here's an example for creating the minimal variant:
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-minimal"
General Configuration
Set Locale
chroot $TARGET_ROOTFS /bin/bash -c "apt-get -y install locales"
chroot $TARGET_ROOTFS /bin/bash -c "echo \"locales locales/locales_to_be_generated multiselect en_US.UTF-8 UTF-8, zh_CN.UTF-8 UTF-8\" | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "echo \"locales locales/default_environment_locale select zh_CN.UTF-8\" | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "sed -i 's/^# zh_CN.UTF-8 UTF-8/zh_CN.UTF-8 UTF-8/' /etc/locale.gen"
chroot $TARGET_ROOTFS /bin/bash -c "dpkg-reconfigure --frontend=noninteractive locales"
Set Time Zone
chroot $TARGET_ROOTFS /bin/bash -c "echo 'tzdata tzdata/Areas select Asia' | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "echo 'tzdata tzdata/Zones/Asia select Shanghai' | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "rm /etc/timezone"
chroot $TARGET_ROOTFS /bin/bash -c "rm /etc/localtime"
chroot $TARGET_ROOTFS /bin/bash -c "dpkg-reconfigure --frontend=noninteractive tzdata"
Set NTP Server
sed -i 's/^#NTP=.*/NTP=ntp.aliyun.com/' $TARGET_ROOTFS/etc/systemd/timesyncd.conf
Set Password
chroot $TARGET_ROOTFS /bin/bash -c "echo root:bianbu | chpasswd"
Configure Network (Optional)
If only the bianbu-minimal package is installed, configure networking via Netplan:
cat <<EOF | tee $TARGET_ROOTFS/etc/netplan/01-netcfg.yaml
network:
version: 2
renderer: networkd
ethernets:
end0:
dhcp4: true
EOF
chroot $TARGET_ROOTFS /bin/bash -c "chmod 600 /etc/netplan/01-netcfg.yaml"
Generate Partition Images
Note: After installation and configuration are complete, make sure to unmount first!
mount | grep "$TARGET_ROOTFS/proc" > /dev/null && umount -l $TARGET_ROOTFS/proc
mount | grep "$TARGET_ROOTFS/sys" > /dev/null && umount -l $TARGET_ROOTFS/sys
mount | grep "$TARGET_ROOTFS/dev/pts" > /dev/null && umount -l $TARGET_ROOTFS/dev/pts
mount | grep "$TARGET_ROOTFS/dev" > /dev/null && umount -l $TARGET_ROOTFS/dev
Generate UUID and write to /etc/fstab:
UUID_BOOTFS=$(uuidgen)
UUID_ROOTFS=$(uuidgen)
cat >$TARGET_ROOTFS/etc/fstab <<EOF
# <file system> <dir> <type> <options> <dump> <pass>
UUID=$UUID_ROOTFS / ext4 defaults,noatime,errors=remount-ro 0 1
UUID=$UUID_BOOTFS /boot ext4 defaults 0 2
EOF
Move boot to another directory to create separate bootfs and rootfs partitions:
mkdir -p bootfs
mv $TARGET_ROOTFS/boot/* bootfs
Create bootfs.ext4 and rootfs.ext4:
mke2fs -d bootfs -L bootfs -t ext4 -U $UUID_BOOTFS bootfs.ext4 "256M"
mke2fs -d $TARGET_ROOTFS -L rootfs -t ext4 -N 524288 -U $UUID_ROOTFS rootfs.ext4 "2048M"
At this point, you will have two partition images, bootfs.ext4 and rootfs.ext4, which can be flashed to a board using fastboot.
