UEFI Firmware and System Image Creation Guide
As of the latest document modification date of July 1, 2025, only products using SPI NOR for booting support UEFI firmware. This document uses the MUSE Pi Pro as an example and be based on Bianbu Minimal 2.2 to introduce how to create RISC-V UEFI firmware and system images based on EDK2.
Document Content Overview
  1. Environment Requirements - Workspace configuration and environment preparation
  2. UEFI Firmware Creation - Compiling and generating the edk2.itb firmware file using EDK2
  3. GRUB Environment Setup - Creating the ESP partition and configuring the GRUB bootloader
  4. Recreating File Systems - Generating bootfs and rootfs partition images
  5. Titan Firmware - Packaging the firmware for Titan Flasher Tool
  6. SDCARD Image Creation - Creating an image file that can be directly written to an SD card
The host machine's environment preparation and the creation of the Bianbu Minimal 2.2 ROOTFS can be found in the Bianbu 2.1/2.2 ROOTFS Creation Guide. After preparing the container environment and ROOTFS, it is possible to proceed with the creation of the UEFI firmware and system image.
First, set up the workspace environment variables to manage the UEFI firmware compilation and image creation:
export UEFI_WORKSPACE=/mnt/uefi-workspace
export ROOTFS_WORKSPACE=/mnt/image-workspace
mkdir -p $UEFI_WORKSPACE
mkdir -p $ROOTFS_WORKSPACE
Then, clean up the previously created partition image files rootfs.ext4 and bootfs.ext4, and integrate the contents of the rootfs and bootfs directories into the working directory. The file system will be recreated later:
# Delete the previously generated partition image files
rm -f rootfs.ext4 bootfs.ext4
# Merge the content of bootfs back into the boot directory of rootfs
mv bootfs/* rootfs/boot/
# Move the integrated rootfs to a dedicated workspace
mv rootfs $ROOTFS_WORKSPACE/rootfs
Before creating the UEFI system image, it is necessary to create the UEFI firmware first. This is because the UEFI firmware is a fundamental component of the system boot process, responsible for hardware initialization and the startup of the bootloader. Traditional U-Boot boot methods require specific U-Boot images, while UEFI boot methods require firmware images that comply with the UEFI standard. By first creating the UEFI firmware (edk2.itb), it is possible to replace the traditional U-Boot image to achieve the UEFI standard boot process.
  1. Install compilation dependencies
    apt install -y git sudo make gcc g++ uuid-dev python3 u-boot-tools 2to3 brotli
  2. Clone the edk2 project code
    edk2 is the core repository of the TianoCore project, providing the basic framework and common code for UEFI firmware development. edk2-platforms is a platform-specific code repository, containing support code and configuration files for various hardware platforms. Both are used together to build UEFI firmware for specific hardware platforms.
    cd $UEFI_WORKSPACE
    git clone https://gitee.com/spacemit-buildroot/edk2.git
    git -C edk2 submodule update --init
    git clone https://gitee.com/spacemit-buildroot/edk2-platforms.git
    git -C edk2-platforms submodule update --init
  3. Compile the UEFI firmware
    cd $UEFI_WORKSPACE
    export GCC5_RISCV64_PREFIX=riscv64-linux-gnu-
    export PACKAGES_PATH=$UEFI_WORKSPACE/edk2:$UEFI_WORKSPACE/edk2-platforms
    export PYTHON_COMMAND=python3
    export WORKSPACE=$UEFI_WORKSPACE
    # Initialize the EDK2 build environment
    cd edk2/
    source edksetup.sh
    cd $UEFI_WORKSPACE
    ln /usr/bin/python3 /usr/bin/python
    # Compile BaseTools
    make -C $UEFI_WORKSPACE/edk2/BaseTools
    # Compile the UEFI firmware
    build -a RISCV64 -p Platform/Spacemit/K1/MUSE-Pi-Pro/MUSE-Pi-Pro.dsc -t GCC5 -b DEBUG
    # Copy the generated ITB firmware file to the ROOTFS file system workspace and rename it
    cp $WORKSPACE/fitimage/MUSE-Pi-Pro/MUSE-Pi-Pro.itb $ROOTFS_WORKSPACE/edk2.itb
  4. Verify the generated firmware file
    After compilation, the generated UEFI firmware file can be found in the ROOTFS file system workspace.
    ls -la $ROOTFS_WORKSPACE/edk2.itb
    This file is the UEFI firmware image for the SpacemiT K1 platform.
GRUB Installation and Configuration
After the UEFI firmware creation is completed, it is necessary to install and configure the GRUB bootloader. GRUB is a multi-boot program that takes over the system boot process after the UEFI firmware initializes the hardware. The UEFI firmware will look for and load the GRUB bootloader stored in the ESP (EFI System Partition). Then, GRUB will load the Linux kernel, device tree, and initramfs according to the configuration file. Therefore, it is necessary to create the ESP partition, install GRUB to the ESP partition, and configure GRUB to correctly identify and boot Bianbu system.
  1. Environment Preparation
    Download and flash the Bianbu 2.2 image to the MUSE Pi Pro. It is recommended to use the Bianbu GNOME Desktop 2.2 firmware version,the method for obtaining the image and the usage of the Titan Flasher tool can be found at Image.
    After flashing the system, ensure that the system can connect to the network and that the network connection is normal, as the process of creating partition files requires downloading software packages.
  2. Create ESP Partition File
    After entering the Bianbu 2.2 system, execute the following commands to create the ESP partition file:
    sudo apt install -y dosfstools
    sudo dd if=/dev/zero of=~/efi.img bs=1M count=200
    sudo mkfs.fat -F32 ~/efi.img
    sudo mkdir -p /boot/efi
    sudo mount ~/efi.img /boot/efi
    sudo apt install -y grub-efi
    sudo grub-install riscv64-efi
    sudo update-grub
    sudo umount /boot/efi
    sudo fsck.vfat -a ~/efi.img
    The created efi.img file is the ESP partition file required. Please transfer this file to the ROOTFS file system workspace, for example using scp for remote transfer.
    Here is a sample transfer command:
    First, execute the following commands on the Muse Pi Pro to obtain the username used to create the ESP partition and the system's IP address.
    whoami
    # Assume the output is: bianbu
    ip a | grep 'inet ' | grep -v '127.0.0.1' | awk '{print $2}' | cut -d'/' -f1
    # Assume the output is: 192.168.10.156
    Then switch to the host environment (note that this is the host environment, not inside the virtual machine) and use the scp command to remotely transfer the efi.img file to the working directory.
    scp username@ip_addr:~/efi.img ~/bianbu-workspace
    # For example: scp bianbu@192.168.10.156:~/efi.img ~/bianbu-workspace
    docker cp ~/bianbu-workspace/efi.img build-bianbu-rootfs:/mnt/image-workspace/
    # This way, the efi.img file has been transferred to the working directory where the system image is being created
    In addition, record the UUIDs of the bootfs and rootfs disk partitions from the Bianbu 2.2 system. When the UEFI system image is built later, it is a must to assign the same UUIDs to rootfs and bootfs. This is necessary because the ESP partition file and system configuration were extracted from the previously flashed Bianbu system. If the new UEFI image uses different UUIDs, the copied configuration files will not correctly identify the new partitions, causing the system to fail to boot.
    # Check the UUID of the rootfs partition:
    blkid -s UUID -o value $(findmnt -n -o SOURCE /)
    # Assume the output is: 964235f6-e9c0-4b6d-9b4d-2567f6630358
    # Check the UUID of the bootfs partition
    blkid -s UUID -o value $(findmnt -n -o SOURCE /boot)
    # Assume the output is: 26d39279-a9ae-485e-8467-dda899d9c3bf
  3. GRUB Configuration
    First, synchronize the obtained UUIDs into environment variables: the UUID for rootfs corresponds to UUID_ROOTFS, and the UUID for bootfs corresponds to UUID_BOOTFS.
    # Replace 'xxxxx' with the corresponding UUID.
    export UUID_ROOTFS=xxxxx
    export UUID_BOOTFS=xxxxx
    # For example:
    # export UUID_ROOTFS=964235f6-e9c0-4b6d-9b4d-2567f6630358
    # export UUID_BOOTFS=26d39279-a9ae-485e-8467-dda899d9c3bf
    After the ESP partition file is ready, install and configure GRUB inside rootfs.
    cd $ROOTFS_WORKSPACE
    # Mount system resources.
    mount -t proc /proc rootfs/proc
    mount -t sysfs /sys rootfs/sys
    mount -o bind /dev rootfs/dev
    mount -o bind /dev/pts rootfs/dev/pts
    mkdir -p rootfs/boot/efi
    # Create a temporary ESP partition image file for the grub-install operation.
    # This temporary file is only used to satisfy grub-install’s installation requirements, allowing it to correctly install GRUB-related files into rootfs within the chroot environment.
    # The actual ESP partition file used is efi.img extracted from the real Bianbu 2.2 system.
    dd if=/dev/zero of=tmp.img bs=1M count=200
    apt update
    mkfs.fat -F32 tmp.img
    mount tmp.img rootfs/boot/efi/
    chroot rootfs /bin/bash -c "apt update"
    chroot rootfs /bin/bash -c "apt install -y grub-efi"
    chroot rootfs /bin/bash -c "grub-install riscv-efi"
    chroot rootfs /bin/bash -c "update-grub"
    chroot rootfs /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get clean"
    # Unmount and delete the temporary ESP partition file, since the actual ESP partition uses efi.img extracted from the real system
    umount tmp.img
    rm tmp.img
    # Unmount system resources.
    mount | grep "rootfs/proc" > /dev/null && umount -l rootfs/proc
    mount | grep "rootfs/sys" > /dev/null && umount -l rootfs/sys
    mount | grep "rootfs/dev/pts" > /dev/null && umount -l rootfs/dev/pts
    mount | grep "rootfs/dev" > /dev/null && umount -l rootfs/dev
    echo 'usb_start=usb start' >> rootfs/boot/env_k1-x.txt
    export UUID_ESP=$(blkid efi.img | grep -o 'UUID="[^"]*"' | cut -d '"' -f 2)
    cat > rootfs/boot/grub/grub.cfg <<EOF
    # DO NOT EDIT THIS FILE
    # It is automatically generated by grub-mkconfig using templates
    # from /etc/grub.d and settings from /etc/default/grub
    ### BEGIN /etc/grub.d/00_header ###
    if [ -s \$prefix/grubenv ]; then
    set have_grubenv=true
    load_env
    fi
    if [ "\${initrdfail}" = 2 ]; then
    set initrdfail=
    elif [ "\${initrdfail}" = 1 ]; then
    set next_entry="\${prev_entry}"
    set prev_entry=
    save_env prev_entry
    if [ "\${next_entry}" ]; then
    set initrdfail=2
    fi
    fi
    if [ "\${next_entry}" ] ; then
    set default="\${next_entry}"
    set next_entry=
    save_env next_entry
    set boot_once=true
    set default="0"
    fi
    if [ x"\${feature_menuentry_id}" = xy ]; then
    menuentry_id_option="--id"
    menuentry_id_option=""
    fi
    export menuentry_id_option
    if [ "\${prev_saved_entry}" ]; then
    set saved_entry="\${prev_saved_entry}"
    save_env saved_entry
    set prev_saved_entry=
    save_env prev_saved_entry
    set boot_once=true
    fi
    function savedefault {
    if [ -z "\${boot_once}" ]; then
    saved_entry="\${chosen}"
    fi
    function initrdfail {
    if [ -n "\${have_grubenv}" ]; then if [ -n "\${partuuid}" ]; then
    if [ -z "\${initrdfail}" ]; then
    set initrdfail=1
    if [ -n "\${boot_once}" ]; then
    set prev_entry="\${default}"
    save_env prev_entry
    fi
    fi
    save_env initrdfail
    fi; fi
    function load_video {
    if [ x\$feature_all_video_module = xy ]; then
    insmod all_video
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
    fi
    if [ x\$feature_default_font_path = xy ] ; then
    font=unicode
    insmod part_gpt
    insmod ext2
    search --no-floppy --fs-uuid --set=root $UUID_ROOTFS
    font="/usr/share/grub/unicode.pf2"
    fi
    if loadfont \$font ; then
    set gfxmode=auto
    load_video
    insmod gfxterm
    set locale_dir=\$prefix/locale
    set lang=zh_CN
    insmod gettext
    fi
    terminal_output gfxterm
    if [ "\${recordfail}" = 1 ] ; then
    set timeout=30
    if [ x\$feature_timeout_style = xy ] ; then
    set timeout_style=menu
    set timeout=10
    # Fallback normal timeout code in case the timeout_style feature is
    # unavailable.
    set timeout=10
    fi
    fi
    ### END /etc/grub.d/00_header ###
    ### BEGIN /etc/grub.d/05_debian_theme ###
    set menu_color_normal=cyan/blue
    set menu_color_highlight=white/blue
    ### END /etc/grub.d/05_debian_theme ###
    ### BEGIN /etc/grub.d/10_linux ###
    function gfxmode {
    set gfxpayload="\${1}"
    set linux_gfx_mode=
    export linux_gfx_mode
    menuentry 'Bianbu GNU/Linux' --class bianbu --class gnu-linux --class gnu --class os \$menuentry_id_option 'gnulinux-simple-$UUID_ROOTFS' {
    load_video
    insmod gzio
    if [ x\$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
    insmod part_gpt
    insmod ext2
    search --no-floppy --fs-uuid --set=root $UUID_BOOTFS
    echo 'Loading Linux 6.6.63 ...'
    linux /vmlinuz-6.6.63 root=UUID=$UUID_ROOTFS ro earlycon=sbi earlyprintk quiet splash plymouth.ignore-serial-consoles plymouth.prefer-fbcon console=ttyS0,115200 loglevel=8 clk_ignore_unused swiotlb=65536 rdinit=\/init workqueue.default_affinity_scope=system rootwait rootfstype=ext4
    echo 'Loading initial ramdisk ...'
    initrd /initrd.img-6.6.63
    echo 'Loading device tree blob...'
    devicetree /spacemit/6.6.63/k1-x_MUSE-Pi-Pro.dtb
    ### END /etc/grub.d/10_linux ###
    ### BEGIN /etc/grub.d/10_linux_zfs ###
    ### END /etc/grub.d/10_linux_zfs ###
    ### BEGIN /etc/grub.d/20_linux_xen ###
    ### END /etc/grub.d/20_linux_xen ###
    ### BEGIN /etc/grub.d/25_bli ###
    if [ "\$grub_platform" = "efi" ]; then
    insmod bli
    fi
    ### END /etc/grub.d/25_bli ###
    ### BEGIN /etc/grub.d/30_os-prober ###
    ### END /etc/grub.d/30_os-prober ###
    ### BEGIN /etc/grub.d/30_uefi-firmware ###
    fwsetup --is-supported
    if [ "\$?" = 0 ]; then
    menuentry 'UEFI Firmware Settings' \$menuentry_id_option 'uefi-firmware' {
    fwsetup
    fi
    fi
    ### END /etc/grub.d/30_uefi-firmware ###
    ### BEGIN /etc/grub.d/35_fwupd ###
    ### END /etc/grub.d/35_fwupd ###
    ### BEGIN /etc/grub.d/40_custom ###
    # This file provides an easy way to add custom menu entries. Simply type the
    # menu entries you want to add after this comment. Be careful not to change
    # the 'exec tail' line above.
    ### END /etc/grub.d/40_custom ###
    ### BEGIN /etc/grub.d/41_custom ###
    if [ -f \${config_directory}/custom.cfg ]; then
    source \${config_directory}/custom.cfg
    elif [ -z "\${config_directory}" -a -f \$prefix/custom.cfg ]; then
    source \$prefix/custom.cfg
    fi
    ### END /etc/grub.d/41_custom ###
    EOF
    Edit the fstab configuration file to enable automatic mounting of the ESP partition.
    cat >rootfs/etc/fstab <<EOF
    # <file system> <dir> <type> <options> <dump> <pass>
    UUID=$UUID_ROOTFS / ext4 defaults,noatime,errors=remount-ro 0 1
    UUID=$UUID_BOOTFS /boot ext4 defaults 0 2
    UUID=$UUID_ESP /boot/efi vfat umask=0077 0 1
    EOF
Recreate the File System
# Create the bootfs directory and move the boot content into it.
mkdir -p bootfs
mv rootfs/boot/* bootfs/
# Generate the new file system.
mke2fs -d bootfs -L bootfs -t ext4 -U $UUID_BOOTFS bootfs.ext4 "256M"
mke2fs -d rootfs -L rootfs -t ext4 -N 524288 -U $UUID_ROOTFS rootfs.ext4 "2048M"
Note: Due to the relatively small file system in Bianbu Minimal builds, the rootfs.ext4 file-system size is set to 2048 MB by default. For Bianbu GNOME Desktop Version or Bianbu LXQt Desktop Version builds, file-system size adjustment according to actual requirements is recommended (e.g., 10240 MB).
Titan Firmware
  1. Install dependencies
    apt -y install zip
  2. Copy the firmware dependency files
    export TMP=$ROOTFS_WORKSPACE/pack_dir
    mkdir -p $TMP/factory/
    # Copy the base firmware files
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_emmc.bin $TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_sd.bin $TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_spinand.bin $TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_spinor.bin $TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/FSBL.bin $TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/u-boot.itb $TMP
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/env.bin $TMP
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/riscv64-linux-gnu/opensbi/generic/fw_dynamic.itb $TMP
    # Create the UEFI firmware file
    cp $ROOTFS_WORKSPACE/edk2.itb $TMP
    # Copy ESP partition files
    cp $ROOTFS_WORKSPACE/efi.img $TMP
    # Copy the file system image
    cp $ROOTFS_WORKSPACE/bootfs.ext4 $TMP
    cp $ROOTFS_WORKSPACE/rootfs.ext4 $TMP
  3. Load reference partition table
    wget -P $TMP https://gitee.com/bianbu/image-config/raw/main/fastboot.yaml
    wget -P $TMP https://gitee.com/bianbu/image-config/raw/main/partition_2M.json
    wget -P $TMP https://gitee.com/bianbu/image-config/raw/main/partition_flash.json
    wget -P $TMP https://gitee.com/bianbu/image-config/raw/main/partition_universal.json
  4. Modify partition table
    Modify the partition_2M.json partition table by replacing the u-boot.itb file with the edk2.itb file:
    # Replace u-boot.itb with edk2.itb
    sed -i 's/"image": "u-boot.itb"/"image": "edk2.itb"/g' $TMP/partition_2M.json
    Modify the partition_universal.json partition table by adding the ESP partition and adjusting the partition order:
    # Use the jq tool to add the ESP partition and adjust the offsets of subsequent partitions
    apt install -y jq
    # Backup the original file
    cp $TMP/partition_universal.json $TMP/partition_universal.json.bak
    # Step 1: Adjust the offsets of existing partitions
    jq '.partitions = (.partitions | map(
    if .name == "bootfs" then
    .offset = "260M"
    elif .name == "rootfs" then
    .offset = "516M"
    end
    ))' $TMP/partition_universal.json > $TMP/partition_universal_temp.json
    # Step 2: Insert the ESP partition after the uboot partition
    jq '.partitions = (
    (.partitions | map(select(.name == "bootinfo" or .name == "fsbl" or .name == "env" or .name == "opensbi" or .name == "uboot"))) +
    "name": "ESP",
    "offset": "4M",
    "size": "256M",
    "image": "efi.img"
    (.partitions | map(select(.name == "bootfs" or .name == "rootfs")))
    )' $TMP/partition_universal_temp.json > $TMP/partition_universal_new.json
    mv $TMP/partition_universal_new.json $TMP/partition_universal.json
    rm $TMP/partition_universal_temp.json
    # Verify the modification results
    echo "=== Modified Partition Configuration ==="
    jq '.partitions[] | select(.name == "uboot" or .name == "ESP" or .name == "bootfs" or .name == "rootfs") | {name, offset, size}' $TMP/partition_universal.json
    # Delete redundant files
    rm $TMP/partition_universal.json.bak
    Modify partition_flash.json by adding edk2.itb and efi.img files to the image array of the bootfs partition:
    cp $TMP/partition_flash.json $TMP/partition_flash.json.bak
    # Use jq tool to add edk2.itb and efi.img to the image array of the bootfs partition
    jq '
    # Add edk2.itb and efi.img to the image array in the bootfs partition
    .image += ["edk2.itb", "efi.img"]
    end
    ' $TMP/partition_flash.json > $TMP/partition_flash_new.json
    mv $TMP/partition_flash_new.json $TMP/partition_flash.json
    echo "=== Image configuration of the bootfs partition ==="
    jq '.partitions[] | select(.name == "bootfs") | .image' $TMP/partition_flash.json
    rm $TMP/partition_flash.json.bak
  5. Shell
    cd $TMP
    # Create the Titan firmware package
    zip -r ../bianbu-custom.zip *
Creating SDCARD Image
For creating an image file directly writable to an SD card, the genimage tool can be used:
  1. Installing genimage tool
    echo 'tzdata tzdata/Areas select Asia' | debconf-set-selections
    echo 'tzdata tzdata/Zones/Asia select Shanghai' | debconf-set-selections
    DEBIAN_FRONTEND=noninteractive apt-get -y install wget python3 genimage
  2. Preparing files for SDCARD image creation
    export SDCARD_TMP=$ROOTFS_WORKSPACE/sdcard_pack_dir
    mkdir -p $SDCARD_TMP/factory/
    # Copying firmware files
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_emmc.bin $SDCARD_TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_sd.bin $SDCARD_TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_spinand.bin $SDCARD_TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/bootinfo_spinor.bin $SDCARD_TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/FSBL.bin $SDCARD_TMP/factory
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/u-boot.itb $SDCARD_TMP
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/u-boot/spacemit/env.bin $SDCARD_TMP
    cp $ROOTFS_WORKSPACE/rootfs/usr/lib/riscv64-linux-gnu/opensbi/generic/fw_dynamic.itb $SDCARD_TMP
    # Copying UEFI-related files
    cp $ROOTFS_WORKSPACE/edk2.itb $SDCARD_TMP
    cp $ROOTFS_WORKSPACE/efi.img $SDCARD_TMP
    # Creating the filesystem image
    cp $ROOTFS_WORKSPACE/bootfs.ext4 $SDCARD_TMP
    cp $ROOTFS_WORKSPACE/rootfs.ext4 $SDCARD_TMP
  3. Loading and modifying partition table configuration
    # Loading the base partition table
    wget -P $SDCARD_TMP https://gitee.com/bianbu/image-config/raw/main/partition_universal.json
    # Modification of the partition table to support UEFI boot
    # Step 1: Adjustment of existing partition offsets
    .offset = "260M"
    .offset = "516M"
    end
    ))' $SDCARD_TMP/partition_universal.json > $SDCARD_TMP/partition_universal_temp.json
    # Step 2: Insertion of the ESP partition after the uboot partition
    jq '.partitions = (
    "name": "ESP",
    "offset": "4M",
    "size": "256M",
    "image": "efi.img"
    )' $SDCARD_TMP/partition_universal_temp.json > $SDCARD_TMP/partition_universal_new.json
    mv $SDCARD_TMP/partition_universal_new.json $SDCARD_TMP/partition_universal.json
    rm $SDCARD_TMP/partition_universal_temp.json
  4. Generation of genimage configuration file
    # Download of genimage configuration generation script
    wget -P $SDCARD_TMP https://gitee.com/spacemit-buildroot/scripts/raw/bl-v1.0.y/gen_imgcfg.py
    # Generation of genimage configuration
    python3 $SDCARD_TMP/gen_imgcfg.py -i $SDCARD_TMP/partition_universal.json -n bianbu-uefi.sdcard -o $SDCARD_TMP/genimage.cfg
  5. Creation of the SDCARD image
    # Creation of temporary directory
    ROOTPATH_TMP="$(mktemp -d)"
    GENIMAGE_TMP="$(mktemp -d)"
    # Generation of the SDCARD image
    genimage \
    --config "$SDCARD_TMP/genimage.cfg" \
    --rootpath "$ROOTPATH_TMP" \
    --tmppath "$GENIMAGE_TMP" \
    --inputpath "$SDCARD_TMP" \
    --outputpath "."
    # Cleanup of temporary directory
    rm -rf "$ROOTPATH_TMP" "$GENIMAGE_TMP"
    echo "=== SDCARD image creation completed ==="
    ls -la bianbu-uefi.sdcard
    Indication of successful packaging upon seeing the following messages:
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'bootinfo' from 'factory/bootinfo_sd.bin' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'fsbl' (in MBR) from 'factory/FSBL.bin' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'env' (in MBR) from 'env.bin' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'opensbi' (in MBR) from 'fw_dynamic.itb' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'uboot' (in MBR) from 'u-boot.itb' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'ESP' (in MBR) from 'efi.img' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'bootfs' (in MBR) from 'bootfs.ext4' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition 'rootfs' (in MBR) from 'rootfs.ext4' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition '[MBR]' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition '[GPT header]' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition '[GPT array]' ...
    INFO: hdimage(bianbu-uefi.sdcard): adding partition '[GPT backup]' ...
    INFO: hdimage(bianbu-uefi.sdcard): writing GPT
    INFO: hdimage(bianbu-uefi.sdcard): writing protective MBR
    INFO: hdimage(bianbu-uefi.sdcard): writing MBR
