Bianbu 2.0 ROOTFS Creation
It is recommended to use Bianbu 2.1/2.2 ROOTFS Creation.
Prerequisites
It is recommended to use Ubuntu 20.04/22.04 as the host system, with Docker CE and a customized version of qemu-user-static (version 8.0.4, with Vector 1.0 support enabled by default) installed.
Docker
For Docker CE installation, refer to https://docs.docker.com/engine/install/.
QEMU
Remove
binfmt-supportThe customized
qemu-user-staticconflicts withbinfmt-supportdue to:binfmt-supportuses a legacy SysVinit script:/etc/init.d/binfmt-support- The customized
qemu-user-staticrelies on a systemd unit:/lib/systemd/system/systemd-binfmt.service
Since the SysVinit script runs after the systemd service, it can override the systemd settings, causing conflicts.
To avoid this, remove
binfmt-support:sudo apt-get purge binfmt-support -
Download the customized qemu
wget https://archive.spacemit.com/qemu/qemu-user-static_8.0.4%2Bdfsg-1ubuntu3.23.10.1_amd64.deb -
Install the customized qemu
sudo dpkg -i qemu-user-static_8.0.4+dfsg-1ubuntu3.23.10.1_amd64.deb -
Register
qemu-user-staticwith the kernel, so the system (including containers) can directly execute RISC-V binaries:sudo systemctl restart systemd-binfmt.service -
Verify if
qemu-user-staticis registered successfullywget https://archive.spacemit.com/qemu/rvv
chmod a+x rvv
./rvvOutput like the following indicates success:
helloworld
spacemit
Prepare the Base ROOTFS
Create a working directory
mkdir ~/bianbu-workspace -
Create and start the container
docker run --privileged -itd -v ~/bianbu-workspace:/mnt --name build-bianbu-rootfs harbor.spacemit.com/bianbu/bianbu:latest -
Enter the container
docker exec -it -w /mnt build-bianbu-rootfs bash -
Install basic tools
apt-get update
apt-get -y install wget uuid-runtime -
Set environment variables
export BASE_ROOTFS_URL=https://archive.spacemit.com/bianbu-base/bianbu-base-24.04-base-riscv64.tar.gz
export BASE_ROOTFS=$(basename "$BASE_ROOTFS_URL")
export TARGET_ROOTFS=rootfs -
Download the base rootfs
wget $BASE_ROOTFS_URL -
Extract to a specified directory
mkdir -p $TARGET_ROOTFS && tar -zxpf $BASE_ROOTFS -C $TARGET_ROOTFS -
Mount system resources into the rootfs
mount -t proc /proc $TARGET_ROOTFS/proc
mount -t sysfs /sys $TARGET_ROOTFS/sys
mount -o bind /dev $TARGET_ROOTFS/dev
mount -o bind /dev/pts $TARGET_ROOTFS/dev/pts
Essential Configuration
Configure the Source Repositories
export REPO="archive.spacemit.com/bianbu"
export VERSION="v2.0.4" -
Configure
sources.sourcescat <<EOF | tee $TARGET_ROOTFS/etc/apt/sources.list.d/bianbu.sources
Types: deb
URIs: https://$REPO/
Suites: noble/snapshots/$VERSION noble-security/snapshots/$VERSION noble-porting/snapshots/$VERSION noble-customization/snapshots/$VERSION
Components: main universe restricted multiverse
Signed-By: /usr/share/keyrings/bianbu-archive-keyring.gpg
EOF
Configure DNS
echo "nameserver 8.8.8.8" >$TARGET_ROOTFS/etc/resolv.conf
Install Hardware-related Packages
chroot $TARGET_ROOTFS /bin/bash -c "apt-get update"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades upgrade"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install initramfs-tools"
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-esos img-gpu-powervr k1x-vpu-firmware k1x-cam spacemit-uart-bt spacemit-modules-usrload opensbi-spacemit u-boot-spacemit linux-image-6.6.36"
Install Metapackages
Different variants have different metapackages:
- Minimal:
bianbu-minimal - Desktop:
bianbu-desktop,bianbu-desktop-zh,bianbu-desktop-en,bianbu-desktop-minimal-en,bianbu-standard,bianbu-development - NAS:
bianbu-nas
Both Desktop and NAS are based on Minimal. It is recommended to install the Minimal metapackage first, and then install the Desktop metapackage.
Here is an example for creating the minimal variant:
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get -y --allow-downgrades install bianbu-minimal"
Tip: After installing all packages, you can run the following command to clean up the cache and reduce the final firmware size.
chroot $TARGET_ROOTFS /bin/bash -c "DEBIAN_FRONTEND=noninteractive apt-get clean"
General Configuration
Set Locale
chroot $TARGET_ROOTFS /bin/bash -c "apt-get -y install locales"
chroot $TARGET_ROOTFS /bin/bash -c "echo \"locales locales/locales_to_be_generated multiselect en_US.UTF-8 UTF-8, zh_CN.UTF-8 UTF-8\" | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "echo \"locales locales/default_environment_locale select zh_CN.UTF-8\" | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "sed -i 's/^# zh_CN.UTF-8 UTF-8/zh_CN.UTF-8 UTF-8/' /etc/locale.gen"
chroot $TARGET_ROOTFS /bin/bash -c "dpkg-reconfigure --frontend=noninteractive locales"
Set Timezone
chroot $TARGET_ROOTFS /bin/bash -c "echo 'tzdata tzdata/Areas select Asia' | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "echo 'tzdata tzdata/Zones/Asia select Shanghai' | debconf-set-selections"
chroot $TARGET_ROOTFS /bin/bash -c "rm /etc/timezone"
chroot $TARGET_ROOTFS /bin/bash -c "rm /etc/localtime"
chroot $TARGET_ROOTFS /bin/bash -c "dpkg-reconfigure --frontend=noninteractive tzdata"
Set Time Server
sed -i 's/^#NTP=.*/NTP=ntp.aliyun.com/' $TARGET_ROOTFS/etc/systemd/timesyncd.conf
Set Password
chroot $TARGET_ROOTFS /bin/bash -c "echo root:bianbu | chpasswd"
Configure Network
- minimal
cat <<EOF | tee $TARGET_ROOTFS/etc/netplan/01-netcfg.yaml
network:
version: 2
renderer: networkd
ethernets:
end0:
dhcp4: true
end1:
dhcp4: true
EOF
chroot $TARGET_ROOTFS /bin/bash -c "chmod 600 /etc/netplan/01-netcfg.yaml"
- desktop
cat <<EOF | tee $TARGET_ROOTFS/etc/netplan/01-network-manager-all.yaml
# Let NetworkManager manage all devices on this system
network:
version: 2
renderer: NetworkManager
EOF
chroot $TARGET_ROOTFS /bin/bash -c "chmod 600 /etc/netplan/01-network-manager-all.yaml"
Note: Different variants only need to configure their respective files.
Generate Partition Images
Note: After installation and configuration are complete, make sure to unmount first!
mount | grep "$TARGET_ROOTFS/proc" > /dev/null && umount -l $TARGET_ROOTFS/proc
mount | grep "$TARGET_ROOTFS/sys" > /dev/null && umount -l $TARGET_ROOTFS/sys
mount | grep "$TARGET_ROOTFS/dev/pts" > /dev/null && umount -l $TARGET_ROOTFS/dev/pts
mount | grep "$TARGET_ROOTFS/dev" > /dev/null && umount -l $TARGET_ROOTFS/dev
Generate UUID and write to /etc/fstab:
UUID_BOOTFS=$(uuidgen)
UUID_ROOTFS=$(uuidgen)
cat >$TARGET_ROOTFS/etc/fstab <<EOF
# <file system> <dir> <type> <options> <dump> <pass>
UUID=$UUID_ROOTFS / ext4 defaults,noatime,errors=remount-ro 0 1
UUID=$UUID_BOOTFS /boot ext4 defaults 0 2
EOF
Move boot to another directory to create separate bootfs and rootfs partitions:
mkdir -p bootfs
mv $TARGET_ROOTFS/boot/* bootfs
Create bootfs.ext4 and rootfs.ext4:
mke2fs -d bootfs -L bootfs -t ext4 -U $UUID_BOOTFS bootfs.ext4 "256M"
mke2fs -d $TARGET_ROOTFS -L rootfs -t ext4 -N 524288 -U $UUID_ROOTFS rootfs.ext4 "2048M"
At this point, you will have two partition images, bootfs.ext4 and rootfs.ext4, which can be flashed to a board using fastboot.
