6.4.3 VSLAM (SVO Series)
This guide uses the VO_MONO module from the SVO-PRO series to implement monocular Visual Odometry (VSLAM).
It provides:
  • Real-time camera tracking
  • Pose estimation
  • Trajectory reconstruction
Designed for localization and mapping on resource-constrained devices, it can be tested using the EuRoC dataset.
Prerequisites:
  • ROS 2 environment installed (ROS 2 Humble recommended)
  • Additional packages:
sudo apt install ros-dev-tools
sudo apt install ros-humble-pcl-ros
Build and Install
Compile the SVO Main Module
colcon build --packages-up-to svo_ros
  • First build may take 1–3 hours
  • For devices with less than 8 GB RAM, set up a SWAP file beforehand
Compile the Local Positioning Module
colcon build --packages-select br_localization
Launch and Usage
Launch the SVO SLAM Node
ros2 launch br_localization slam_svo.launch.py
Play the EuRoC Dataset in ROS 2 Format
Use ros2 bag play to replay the converted ROS 2 Bag data (see the next section for the data-conversion steps):
ros2 bag play ~/V2_02_medium
Ensure the following topics are being published:
  • /cam0/image_raw
  • /imu0
EuRoC Dataset Conversion Tool (ROS1 → ROS2)
The EuRoC dataset comes as image + IMU CSV files and needs conversion into a ROS 2 .db3 Bag.
Conversion Script euroc_converter.py
Save the following Python script as euroc_converter.py:
#!/usr/bin/env python3
# euroc_converter.py
from rclpy.serialization import serialize_message
from rosbag2_py import SequentialWriter, StorageOptions, ConverterOptions, TopicMetadata
from sensor_msgs.msg import Imu
from builtin_interfaces.msg import Time
import os
from cv_bridge import CvBridge
import csv
import shutil
def create_bag(image_folder, timestamp_file, imu_file, output_bag):
# Initialize ROS2 (serialization required)
if os.path.exists(output_bag):
shutil.rmtree(output_bag)
# Create bag writer
writer = SequentialWriter()
storage_options = StorageOptions(uri=output_bag, storage_id='sqlite3')
converter_options = ConverterOptions(input_serialization_format='cdr',
output_serialization_format='cdr')
writer.open(storage_options, converter_options)
# Create image topic
image_topic = '/cam0/image_raw'
image_msg_type = 'sensor_msgs/msg/Image'
writer.create_topic(
TopicMetadata(
name=image_topic,
type=image_msg_type,
# Create IMU topic
imu_topic = '/imu0'
imu_msg_type = 'sensor_msgs/msg/Imu'
TopicMetadata(
name=imu_topic,
type=imu_msg_type,
# Read image timestamp file
image_timestamps = []
with open(timestamp_file, 'r') as f:
reader = csv.reader(f)
next(reader) # skip header
for row in reader:
image_timestamps.append(int(row[0]))
# Read IMU data
imu_data = []
with open(imu_file, 'r') as f:
for row in reader:
# CSV expected format: timestamp,gyro_x,gyro_y,gyro_z,acc_x,acc_y,acc_z
imu_data.append({
'timestamp': int(row[0]),
'gyro': [float(row[1]), float(row[2]), float(row[3])],
'acc': [float(row[4]), float(row[5]), float(row[6])]
# Ensure all image files exist
image_files = sorted([f for f in os.listdir(image_folder) if f.endswith('.png')])
if len(image_files) != len(image_timestamps):
print(f"Warning: number of images ({len(image_files)}) does not match number of timestamps ({len(image_timestamps)})")
exit()
bridge = CvBridge()
# Write image data
for i, (ts, img_file) in enumerate(zip(image_timestamps, image_files)):
# Load image
img_path = os.path.join(image_folder, img_file)
cv_img = cv2.imread(img_path, cv2.IMREAD_GRAYSCALE)
if cv_img is None:
print(f"Warning: unable to read image {img_path}")
exit()
# Convert to ROS Image message
img_msg = bridge.cv2_to_imgmsg(cv_img, encoding='mono8')
# Set timestamp
t = Time()
t.sec = ts // 10**9
t.nanosec = ts % 10**9
img_msg.header.stamp = t
img_msg.header.frame_id = 'cam0'
# Write to bag
writer.write(
image_topic,
serialize_message(img_msg),
ts
if i % 100 == 0:
print(f'Processed {i+1}/{len(image_files)} images')
# Write IMU data
for i, imu in enumerate(imu_data):
# Create IMU message
imu_msg = Imu()
# Set timestamp
ts = imu['timestamp']
t = Time()
t.sec = ts // 10**9
imu_msg.header.stamp = t
imu_msg.header.frame_id = 'imu0'
# Set angular velocity (gyro)
imu_msg.angular_velocity.x = imu['gyro'][0]
imu_msg.angular_velocity.y = imu['gyro'][1]
imu_msg.angular_velocity.z = imu['gyro'][2]
# Set linear acceleration (acc)
imu_msg.linear_acceleration.x = imu['acc'][0]
imu_msg.linear_acceleration.y = imu['acc'][1]
imu_msg.linear_acceleration.z = imu['acc'][2]
# Write to bag
writer.write(
imu_topic,
serialize_message(imu_msg),
ts
if i % 1000 == 0:
print(f'Processed {i+1}/{len(imu_data)} IMU samples')
# Close bag
del writer
print(f'Bag file saved to {output_bag}')
import argparse
parser = argparse.ArgumentParser()
parser.add_argument('--folder', required=True)
args = parser.parse_args()
folder : str = args.folder
if folder.endswith('/'):
folder = folder[:-1]
bag_name = folder.split('/')[-1]
image_folder = os.path.join(folder,'mav0', 'cam0', 'data')
imu_csv = os.path.join(folder, 'mav0', 'imu0', 'data.csv')
timestamp_csv = os.path.join(folder, 'mav0', 'cam0', 'data.csv')
create_bag(image_folder, timestamp_csv, imu_csv, bag_name)
Run the Conversion Command
The conversion command is:
python3 euroc_converter.py --folder /path/to/your/euroc_folder
Example:
python3 euroc_converter.py --folder ~/V2_02_medium/mav0
# After conversion, a ROS 2 Bag is created in the folder
After a successful conversion, a ROS 2 Bag package named V2_02_medium (same as the dataset folder) will be created in the current directory, containing:
  • /cam0/image_raw Monochrome image frames (monocular)
  • /imu0 Raw IMU data (angular velocity + linear acceleration)
