6.4.7 Mobile Robot Human Following
This section demonstrates human-following functionality for a mobile robot, which includes USB-camera image acquisition, human detection, and velocity decision-making.
For convenience, we observe the robot’s motion in the Gazebo simulator; you can also deploy it on a real robot that supports ROS 2 chassis velocity control.
  • The human-following algorithm runs on a SpacemiT RISC-V board.
  • The Gazebo simulation runs on a PC connected to the same network.
On SpacemiT RISC-V Board
  1. Flash the Bianbu ROS system image to the board.
  2. Install required dependencies:
On x86 PC
  1. Install Ubuntu 22.04.
  2. Set up ROS 2 Humble.
  3. Install the mobile robot model and Gazebo simulation packages:
Usage Guide
Launch the Simulation Environment
Run the following command to load the robot model and start the Gazebo simulation environment:
ros2 launch turtlebot3_gazebo empty_world.launch.py
After successful launch, the simulation environment will look like this:
Launch the Human-Following Algorithm
On the SpacemiT RISC-V board, launch the human-following algorithm; make sure a USB camera is plugged in beforehand.
The robot’s policy is to follow the target closest to the image center until it reaches a short-range threshold, then stop.
Default linear speed is 0.1 m/s and angular speed is 0.37 rad/s; both can be tuned via the launch-file parameters.
The robot's following strategy is to select the target closest to the center of its view and then follow it until it reaches a relatively close distance, at which point it stops.
  • Default motion parameters:
    • Linear speed: 0.1 m/s
    • Angular speed: 0.37 rad/s
  • These can be adjusted in the launch file parameters.
Hardware Connection
Check the camera device ID:
➜  ~ ls /dev/video*
/dev/video0 /dev/video10 /dev/video12 /dev/video14 /dev/video16 /dev/video18 /dev/video2 /dev/video21 /dev/video4 /dev/video50 /dev/video6 /dev/video8 /dev/video-dec0
/dev/video1 /dev/video11 /dev/video13 /dev/video15 /dev/video17 /dev/video19 /dev/video20 /dev/video3 /dev/video5 /dev/video51 /dev/video7 /dev/video9
Unplug and replug the camera to confirm the device index. The default device used in the program is /dev/video20.
Start the Following Node
Open a terminal and run:
# Source ROS 2 environment
ros2 launch br_application agv_person_follow.launch.py
You should see logs similar to:
[INFO] [launch]: All log files can be found below /home/zq-pi/.ros/log/2025-06-12-16-07-34-737169-spacemit-k1-x-MUSE-Pi-board-89537
[INFO] [agv_follow_node-1]: process started with pid [89544]
[agv_follow_node-1] [INFO] [1749715663.222242636] [agv_follow_node]: AI tracking-control service started, current state: paused
To accommodate multitasking scenarios, the following node launches a service that can control whether following is enabled or not.
You can quickly enable this service from a terminal:
ros2 service call /toggle_follow std_srvs/srv/SetBool "{data: true}"
Expected output:
[agv_follow_node-1] [INFO] [...] [agv_follow_node]: Received request: data=True → AI tracking module ON
To disable the service, use:
ros2 service call /toggle_follow std_srvs/srv/SetBool "{data: false}"
To use this service within your code:
from std_srvs.srv import SetBool
class FollowClient(Node):
super().__init__('follow_control_client')
self.cli = self.create_client(SetBool, 'toggle_follow')
# Wait for the service to become available
self.get_logger().info('Waiting for toggle_follow service...')
def send_request(self, enable: bool):
req = SetBool.Request()
req.data = enable
future = self.cli.call_async(req)
self.get_logger().info(f'Response: success={future.result().success}, message="{future.result().message}"')
self.get_logger().error('Service call failed')
def main():
client = FollowClient()
client.send_request(True) # True = start tracking
client.destroy_node()
Follow-node terminal output:
[agv_follow_node-1] cmd_vel -- linear_x:0.0, angular_z:0.0
[agv_follow_node-1] cmd_vel -- linear_x:0.4, angular_z:0.0
Move away from the camera or move side to side. You should observe the robot moving accordingly in Gazebo.
View Detection Results
To view the human-target detection results, relaunch with the following parameter:
ros2 launch br_application agv_person_follow.launch.py publish_result_img:=true
The topic is published to /detection_image. To view it on PC, run
rqt_image-view rqt_image-view
Configurable Parameters
Parameter reference for agv_person_follow.launch.py
ParameterPurposeDefault
video_deviceCamera device index/dev/video20
publish_result_imgWhether to publish the detection imageFalse
linear_xFollowing linear speed0.4 m/s
angular_zFollowing angular speed0.37 rad/s
Human-Following on a Real Robot
On a real robot, tilt the camera upward slightly for better recognition performance.
