6.4.8 Human Pose Detection
YOLOv8-Pose Model Overview
YOLOv8-Pose is a Pose Estimation Model from Ultralytics' YOLOv8 series. It detects human keypoints (like head, shoulders, knees) and builds on YOLOv8's architecture for fast, accurate 2D pose estimation. Typical applications include:
  • Security surveillance
  • Sports analytics
  • Human-computer interaction
  • Robotics
This guide shows how to:
  1. Run YOLOv8-Pose inference on images or video streams using SpacemiT hardware
  2. Publish detection results (bounding boxes + human keypoints) via ROS 2
Install Dependencies
Source ROS2 Environment
Check Available Models
List available pose estimation models:
ros2 launch br_perception infer_info.launch.py | grep 'pose'
[list-1]   - config/pose/yolov8_pose.yaml
For subsequent inference tasks, set the config_path parameter to the corresponding .yaml file path to use that specific pose estimation model.
Human Keypoint Definitions
The model detects these keypoints as:
Keypoint indices and names:
0. Nose
1. Left eye
2. Right eye
3. Left ear
4. Right ear
5. Left shoulder
6. Right shoulder
7. Left elbow
8. Right elbow
9. Left wrist
10. Right wrist
11. Left hip
12. Right hip
13. Left knee
14. Right knee
15. Left ankle
16. Right ankle
Image Inference
Prepare a Test Image
Run Inference and Save Results Locally
config_path:='config/pose/yolov8_pose.yaml' \
img_path:='./test.jpg'
Results are saved as pose_result.jpg in the current directory:
Terminal outputs detailed detection information:
bianbu@bianbu:~$ ros2 launch br_perception infer_img.launch.py   config_path:='config/pose/yolov8_pose.yaml'   img_path:='./test.jpg'
[INFO] [launch]: All log files can be found below /home/bianbu/.ros/log/2025-07-29-11-38-09-728349-bianbu-13624
[INFO] [infer_img_node-1]: process started with pid [13631]
[infer_img_node-1] All model files already exist and do not need to be downloaded
[infer_img_node-1] all time cost:0.11103701591491699
[infer_img_node-1]
[infer_img_node-1] Person 0, [xmin:0, ymin:203, width:87, height:151], conf 0.42
[infer_img_node-1] nose: (49.0, 131.0), vis=1.32
[infer_img_node-1] left_eye: (55.0, 131.0), vis=1.32
[infer_img_node-1] right_eye: (49.0, 123.0), vis=1.32
[infer_img_node-1] left_ear: (63.0, 131.0), vis=1.32
[infer_img_node-1] right_ear: (49.0, 131.0), vis=0.00
[infer_img_node-1] left_shoulder: (63.0, 150.0), vis=1.32
[infer_img_node-1] right_shoulder: (41.0, 150.0), vis=1.32
[infer_img_node-1] left_elbow: (55.0, 191.0), vis=1.32
[infer_img_node-1] right_elbow: (16.0, 174.0), vis=1.32
[infer_img_node-1] left_wrist: (16.0, 183.0), vis=1.32
[infer_img_node-1] right_wrist: (16.0, 174.0), vis=1.32
[infer_img_node-1] left_hip: (63.0, 230.0), vis=1.32
[infer_img_node-1] right_hip: (41.0, 230.0), vis=1.32
[infer_img_node-1] left_knee: (63.0, 288.0), vis=1.32
[infer_img_node-1] right_knee: (41.0, 288.0), vis=1.32
[infer_img_node-1] left_ankle: (80.0, 335.0), vis=1.32
[infer_img_node-1] right_ankle: (49.0, 335.0), vis=1.32
[infer_img_node-1]
[infer_img_node-1] Person 1, [xmin:1, ymin:112, width:39, height:238], conf 0.85
Web-Based Visualization
Terminal 1 - Start inference node:
img_path:='./test.jpg' \
Terminal 2 - Launch web visualization:
The terminal will print the message as:
Open a browser and visit the URL shown in the terminal (e.g., http://<IP>:8080) to view results:
Subscribe to Results
To view the inference results by
Or use this Python script to subscribe to inference results:
from jobot_ai_msgs.msg import DetectionPoseResultArray
class PoseSubscriber(Node):
super().__init__('pose_subscriber')
DetectionPoseResultArray,
'/inference_result', # Topic name, can be changed
10 # QoS
self.get_logger().info(f"Received pose results: {len(msg.results)} persons")
for det_id, res in enumerate(msg.results):
f"\nPerson {det_id}, [xmin:{res.x_min}, ymin:{res.y_min}, "
f"width:{res.width}, height:{res.height}], conf {res.conf:.2f}"
for i in range(len(res.keypoint_ids)):
name = f"kp_{res.keypoint_ids[i]}"
x = res.keypoint_xs[i]
y = res.keypoint_ys[i]
conf = res.keypoint_confs[i]
self.get_logger().info(f" {name}: ({x:.1f}, {y:.1f}), vis={conf:.2f}")
node = PoseSubscriber()
Parameters Description
infer_img.launch.py Parameters
ParameterDescriptionDefault
config_pathPath to the model configuration file used for inferenceconfig/detection/yolov6.yaml
img_pathPath to the image file to run inference ondata/detection/test.jpg
publish_result_imgWhether to publish the detection result as an image messagefalse
result_img_topicTopic name for rendered image output (only valid if publish_result_img = true)/result_img
result_topicTopic name for the inference result message/inference_result
Video Stream Inference
Start USB Camera
Run Inference & Publish results
Terminal 1 - Start inference:
Open a browser and visit the URL shown in the terminal (e.g., http://<IP>:8080) to view results.
Data-Only Inference (No Visualization)
If you only want to obtain the model inference results, run the following command:
10 # QoS
Parameters Descriptions
infer_video.launch.py Parameters
Parameter NameDescriptionDefault Value
config_pathPath to the model configuration file for inferenceconfig/detection/yolov6.yaml
sub_image_topicImage topic to subscribe to/image_raw
publish_result_imgWhether to publish the rendered inference imagefalse
result_img_topicImage topic to publish (only when publish_result_img=true)/result_img
result_topicInference-result topic to publish/inference_result
